Ideas for anti theft system on Jeep - Page 4 - JeepForum.com
post #46 of 108 Old 12-12-2009, 12:14 PM
vindicated
Did you miss me?
vindicated's Avatar
Originally Posted by Terrible2 View Post
Why the heck would someone go through that much trouble, seems like alot more pain than flicking a switch? just get simple kill switches
Because thieves look for kill switches.. I carry my fingers with me so it wouldnt be hard to flick a switch. Trust me they would find it. I remove the #6 starter fuse in mine and never worry a minute. Although, I do worry constantly about someone cutting my top.
Originally Posted by bradthebard
Vin's so hard core, he drinks the whole jug of STFU and then has a three hour conversation about it.
vindicated is offline
post #47 of 108 Old 12-12-2009, 02:03 PM
NonRubicon
The trick to kill switches is to install them using existing wiring looms as much as possible and to put them in looms where there arent any - this goes for in the cab and the engine compartment. Make it look stock - use electrical tape and zip ties to secure added looms like a professional installation from the factory. Over time the looms will get dirty and blend in. The switch is best placed in a location that can be locked up securely, or is of an unorthodox/complex design.
It's a fair bet that thieves troll the boards looking for ideas on where to search for a kill switch. Avoid common locations that are posted all over the net, but the switch shouldn't be placed in a spot too inconvenient for regular use. Get creative. I think it's a good idea to not discuss where you have one installed, unless your vehicle was stolen.
NonRubicon is offline
post #48 of 108 Old 12-12-2009, 02:13 PM
southbound
Originally Posted by tporter View Post
I have a 1992 yj soft top. Unfortunately I live in a area in Southern California where vehicle thefts run fairly high. I would like to put some type of device on my jeep that will make it harder to steal. I thought about a switch that I can hit that would shut off battery power, this way if they punch the ignition it still won't start. Any thoughts on this, is there a better solution out there that can help prevent someone from taking my jeep?
I remember somebody makes a battery kill switch that can be switched on and off via a hand held remote like a keyless entry system. I can't remember who makes it, but I'll look around and see if I can find it. It seems to me that this would be perfect when combo'd with a hood lock (cheap at around $15-20).
5.7L Hemi TJ Build: http://forum.aev-conversions.com/showthread.php?t=7434
southbound is offline
post #49 of 108 Old 12-12-2009, 02:16 PM
southbound
I think this is it-
BatteryBrain
post #50 of 108 Old 12-12-2009, 02:51 PM
Floppy
Floppy's Avatar
I think this is it-
BatteryBrain
It was already mentioned earlier in the thread. It's kinda expensive for what it does (around $80-$90). The wireless FOB switch I posted is much cheaper and disables the fuel pump so it won't be able to start.
1990 Jeep Wrangler YJ -
2001 Mustang GT Vert (supercharged)
2004 Lincoln Aviator (daily driver)
2006 Yamaha V Star 1100 Custom
1974 Volkswagen Super Beetle (sunroof and 1904cc motor)
1972 Volkswagen Super Beetle (wolfsburg edition)
Floppy is offline
post #51 of 108 Old 12-12-2009, 03:09 PM
JoeR203
Years ago, Summit Racing sold a kit that is plumbed thru the brake lines. When the alarm was tripped, the brakes were locked. You could also use a bicycle cable lock strung thru the wheels and, if they do end up getting your ride, a Zoombak unit may help you find it.
Whoever said "Money can't buy happiness" didn't know where to shop.
JoeR203 is offline
post #52 of 108 Old 12-12-2009, 05:34 PM
unihall
Battery brain.
the battery brain is remote control. It has a key fob. The good thing about a battery kill like the battery brain is once the thief breaks in to your jeep it seems like all is right. The lights work and everything seems normal. Then as soon as he tries to start it the jeep kinda cranks for a second and then just goes dead just like a dead battery. He is most likely out of there then because I don't know of anyway to start a jeep without a battery unless you start on a big hill or have a lot of people to push. Once you set it up you don't have to go under the hood. The fuel shut off is good also. If you do anything it will help. So many people are either stupid or lazy because they don't do anything. With all those unprotected jeeps out there they will go elsewhere.
unihall is offline
post #53 of 108 Old 12-12-2009, 10:19 PM
Terrible2
Seems like way more work than necessary. I guess if you really want to do that much work for your safety. Id still rather would rather go for a hidden kill switch, but heck cant force my opinions on ya
Terrible2 is offline
post #54 of 108 Old 12-13-2009, 10:37 AM
TheRobster
I had this idea a while ago.
Get an RFID reader and install the sensor for it in the drivers seat.
Stash the rest of the electronics somewhere where it won't be easily noticed, use it to cut power to the fuel pump, or coil. Do everything you can to make it look like the extra wires belong there.
Then you just carry a RFID card in your wallet. Jeep won't start if you aren't in it. Jeep dies within seconds if you hop out.
You could even have some fun with your friends, or make a few $ off strangers, by betting them they couldn't start your Jeep.
Of course I am a lazy bastard, so I just put on the club and walk away.
Check out my cheep bastard Jeep mod blog.
TheRobster is offline
post #55 of 108 Old 12-13-2009, 10:48 AM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
These work pretty good for me.....
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #56 of 108 Old 12-13-2009, 01:54 PM
southbound
I didn't read through the first 3 pages of the thread. Just the OP's initial question. The batterybrain was the first thing that came to mind, so I posted it.
And I read your idea, but honestly I would still go with the BatteryBrain if I had the extra money to spend on it and really wanted to install an anti-theft device. I also like the other features their product offers. I like the fact that it monitors the battery and isolates it so you can at least have a chance at turning your engine over and not have to break out the cables.
post #57 of 108 Old 12-16-2009, 11:19 AM
kkchevy3
does anyone know of a magnetic switch. You could mount it anywhere in your jeep and just pass a magnet infront of it to turn you say fuel pump on. Unless a theif knows you have it and wants to sit in ur jeep waving a magnet around there not gona start your jeep
kkchevy3 is offline
post #58 of 108 Old 12-16-2009, 11:52 AM
Fuddmaster
I still a crappy jeep not worth stealin. so that helps. but i take my faceplate in with me and use a hoodlock never had a problem.
Fuddmaster is offline
post #59 of 108 Old 12-16-2009, 12:27 PM
Mud-Hunter
I just lock the doors and say a prayer. So far so good. I did clean out the garage to have my 1st ever real Jeep work place and it feels nice to put my baby in there each night. I'm up at weird hours and love to have "Night Mornings" as it's nice to not have the kids up and mom asking me for this and that. Changed my differentail fluids at 2am last Saturday. So if a thief is coming he best be ready as I might just greet him at the door. Hopefully with a big *** wrench in my hand.
Mud-Hunter is offline
post #60 of 108 Old 12-16-2009, 12:36 PM
amike_321
why not take the wheels off and leave it on cinder blocks?
amike_321 is offline
Creative anti-theft ideas dirtyjpwrangler Wrangler General Discussion 29 01-05-2010 07:36 PM
I can start my jeep without the key in the ignition, any anti-theft ideas? jmurds YJ Wrangler Technical Forum 12 12-31-2009 11:29 AM
Anyone have any good Anti-Theft ideas? JeepinYahoo TJ Wrangler Technical Forum 59 04-18-2006 07:10 AM
Anti-theft key system bandit5150 TJ Wrangler Technical Forum 9 04-25-2005 01:29 PM
Winch Anti-theft ideas? 94YJ_FL YJ Wrangler Technical Forum 10 04-02-2004 03:32 PM
