Ideas for anti theft system on Jeep - Page 3 - JeepForum.com
post #31 of 108 Old 12-12-2009, 01:29 AM
Terrible2
Originally Posted by jerseyrider1119 View Post
starter fuse is located under the hood in front of the battery
Why the heck would someone go through that much trouble, seems like alot more pain than flicking a switch? just get simple kill switches
Terrible2 is offline
post #32 of 108 Old 12-12-2009, 01:30 AM
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
What's the best way to wire in a switch for the fuel pump? Does anyone have a write up for this?
Amp'd 2014 JK -
Past - 95YJ 99XJ 98XJ 05WK 94XJ
biggn235 is offline
post #33 of 108 Old 12-12-2009, 01:41 AM
Terrible2
I think i saw how to make a kill switch the other week on the home page = ( now its gone
post #34 of 108 Old 12-12-2009, 01:44 AM
ImpactFabWorks
you could just disconnect the ground from the starter and run it to a switch. I have a push button switch so i have to run the key and push the button or the starter turn
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #35 of 108 Old 12-12-2009, 08:11 AM
Jesse-James
Jesse-James's Avatar
1989 XJ Cherokee
X2, if you make whatever you do anything but convenient, you will end getting lazy and not using it all the time.
Live in SE WI? ----->
Jesse-James is offline
post #36 of 108 Old 12-12-2009, 08:52 AM
CLIMBaMTN
just do a hidden kill switch...wire and a switch will run about $10 or less...
all these comments about "if they want it, they will tow it"....lol....ain't no theif gonna waste their time to steal a YJ with a tow truck...probably only a joyriding idiot car thief would target any jeep in the first place
CLIMBaMTN is offline
post #37 of 108 Old 12-12-2009, 08:57 AM
Jesse-James
1989 XJ Cherokee
Jeeps of all types are a hot commodity to thieves because of the parts value and demand for said parts.
post #38 of 108 Old 12-12-2009, 09:03 AM
Floppy
Floppy's Avatar
Originally Posted by Why J? View Post
Doesn't somone make a relay that will kill any circuit it is plugged into with a key FOB? I saw this in a JP article a few months ago.
Basically it's just a relay and you plug it into say your fuel relay and when it is deactivated with the Key fob it kills that circuit. Would take a thief a little while to figure out.
I saw the same thing in JP a while back. I haven't been able to find it since. Has anyone else seen this? Unless the theif is carrying around spare relays it's not going to start.
Originally Posted by unihall View Post
That and a hood lock. I bought one at camping world. It hooks to your battery and has a key fob that you use to activate it. It actually has three functions. If your battery gets down to 11 volts it shuts off the whole system that way when you get there hopefully there will be enough juice to start your engine. So I live in Southern Kaulifornia land of the expensive DMV and many crooks.
So I park my jeep push the disable button and put a steering wheel lock on. The last guy that tried to steal it cut the steering wheel to get the club off. Then he pulled the ignition, stuck in the old screwdriver and turned. The battery brain when it is set lets the engine start to turn over but to me it sounds just like a dead battery. Must have to this guy also. He hopped out and when he got to the hood and found the hood lock, well he gave up then probably figuring I had a dead battery. In the morning I set the battery brain and used his screwdriver to start my jeep. What a PITA to fix a yj ignition lock. I try to keep it in the garage now but I thank the battery brain for my jeep
That sounds like a pretty cool idea. I haven't seen them before.
1990 Jeep Wrangler YJ -
2001 Mustang GT Vert (supercharged)
2004 Lincoln Aviator (daily driver)
2006 Yamaha V Star 1100 Custom
1974 Volkswagen Super Beetle (sunroof and 1904cc motor)
1972 Volkswagen Super Beetle (wolfsburg edition)
Floppy is offline
post #39 of 108 Old 12-12-2009, 09:05 AM
ZeroGravity
I would go for a battery kill switch, hood lock, and fuel pump kill switch. The battery switch can be mounted under the hood, so someone would need to bust the hood lock, look around for that switch, and then try to start it with no fuel getting to the engine.All on top of motion sensor alarm.
I'm sure a good car theif would be able to get past that system given some time, but having the alarm can give you a heads up that something is going on. I can definately book it to my Jeep with a bat/gun/whatever in less time than it would take to figure that out.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #40 of 108 Old 12-12-2009, 09:11 AM
Jesse-James
1989 XJ Cherokee
Keep in mind too with a battery kill switch, you're going to be pissed off every time you turn on the radio and all the settings are reset. So now you have another wire to run for that.
You can pick up a decent alarm for $50 if you can wire it yourself, why not do it the right way?
post #41 of 108 Old 12-12-2009, 10:55 AM
unihall
Battery Brain
When you hook up the battery brain to your battery it comes with all the wires and instructions to install it. It took me about 10 minutes to hook it up. it has a by pass function that keeps all your electronics up to snuff, in other words you do not lose any of your settings.BatteryBrain. The web site if you are interested. The real fact is that just about anything you do will help keep thieves from your jeep. The more sophisticated you get the harder it will be for them. In the end sadly if a pro wants your jeep he will probably get it.
unihall is offline
post #42 of 108 Old 12-12-2009, 10:59 AM
unihall
Motion alarm
A good one is also a good idea. I know that no one seems to listen to them but in the middle of the night it sounds like all hell broke lose to a thief. And lastly don't forget to try and have some good insurance. Most of the insurance companies will rip you off if you give them a chance, but something is better than nothing if you are unfortunate enough to have your jeep stolen.
unihall is offline
post #43 of 108 Old 12-12-2009, 11:09 AM
beachedjeepyj
so far im good on preventing my 88 from being stolen, all i need to do is dont fix the carb because whenever you push down on the pedal it stalls
by the time the figure out how lightly to press the pedal down ill be walking next to them with my dads billy club
Originally Posted by Jeep89JV View Post
Do I let others drive my rig? No -- Why, because if this ship sinks i'll be the captain and I go down with this ship.
beachedjeepyj is offline
post #44 of 108 Old 12-12-2009, 11:28 AM
StreetBMXer88
.45 Acp............
StreetBMXer88 is offline
post #45 of 108 Old 12-12-2009, 11:29 AM
Floppy
Floppy's Avatar
Another good idea is to install a 12volt Wireless FOB switch like this- Remote control fuel kill switch. Something different! Anyone done this? - MX-5 Miata Forum in between your fuel pump relay and pump. It's a $30 switch that will turn off your fuel pump wirelessly. Battery cut-offs are good ideas but the harder you make it for yourself to arm your security device, the less likely you are to actually do it. I know I'm not going to open my hood, turn off the battery and then lock my hood back down every time I go somewhere. The wireless switch is a good idea because you can do it as you're walking away, just like a car alarm.
Floppy is offline
Creative anti-theft ideas dirtyjpwrangler Wrangler General Discussion 29 01-05-2010 07:36 PM
I can start my jeep without the key in the ignition, any anti-theft ideas? jmurds YJ Wrangler Technical Forum 12 12-31-2009 11:29 AM
Anyone have any good Anti-Theft ideas? JeepinYahoo TJ Wrangler Technical Forum 59 04-18-2006 07:10 AM
Anti-theft key system bandit5150 TJ Wrangler Technical Forum 9 04-25-2005 01:29 PM
Winch Anti-theft ideas? 94YJ_FL YJ Wrangler Technical Forum 10 04-02-2004 03:32 PM
