ID connectors on engine block "What is it?".... - JeepForum.com
post #1 of 3 Old 05-17-2010, 03:18 PM Thread Starter
Chris Aunchman
1987 YJ Wrangler
Hey,
So I have a 1987 Wrangler 258 and need some help IDing a few things. I just stripped the motor completely, trying to clean it up in the by and jsut curious about a few connectors.
First:
What is the connector right below the oil pressure sending unit?
I'm guesing it is for the low oil pressure light??? I didn't even think I
had one.
Second:
After taking off the intake/exhaust mainfold I noticed on the last
freeze plug it looks like a little connector? What is it? Is this some
kind of coolant temp sensor?
Thanks,
Chris
Chris Aunchman is offline
post #2 of 3 Old 05-17-2010, 05:31 PM
Burnerman
Burnerman's Avatar
First- it's the oil pressure switch for the electric choke. Second- it sounds like you have a rebuilt engine in the Jeep. Rebuilders use an overheat tattle tale disc on the front most freeze plug. If you overheat the remanufactured engine in the warrenty period they can tell by that disc.
Have you been to this site? http://home.sprynet.com/~dale02/ It may help you out.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #3 of 3 Old 05-17-2010, 08:07 PM Thread Starter
Chris Aunchman
1987 YJ Wrangler
Thanks, That is an AWESOME site!!! Correct me if I'm wrong though but I did a MC2100, best thing I ever did, last year and I don't think alot of that stuff pertains to me. I been wondering how much I can get rid of from under the hood. I have never seen a "overheat tattle tale disc", now the one I am looking at is the rear most freeze plug towards the rear of the engine. Would this come form the factory?
Thanks,
Chris
Where is "instrument panel junction block"? pipelineaudio TJ Wrangler Technical Forum 1 06-15-2008 03:31 PM
"Rattle from in front of the block" FIXED!!!!!! Gritz TJ Wrangler Technical Forum 0 04-28-2008 11:24 PM
"clock" tap in fuse block dankeenan YJ Wrangler Technical Forum 2 03-26-2008 05:13 AM
03+ owners w/ auto and the O/D "vibe" or "engine lug" BIGNUTT TJ Wrangler Technical Forum 7 03-02-2007 01:40 PM
Soft-top "connectors" bmd6482 YJ Wrangler Technical Forum 5 01-16-2005 10:52 PM
