I want to up grade my sound system. For cheap - JeepForum.com
post #1 of 8 Old 09-17-2012, 08:51 PM Thread Starter
MyJeepWillRock
At the moment my radio doesn't even work but I want to fix it.
- I want to put 2 8 in. subs under/in my rear seat.
*I have saw people talking about it but i don't know how to do that.
And the wiring how would I do that, what do i need to connect the subs to my radio and make it work and Bump?
MyJeepWillRock is offline
post #2 of 8 Old 09-17-2012, 11:53 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You are going to have to do a little research to make this idea work properly. The only component you're leaving out is the amplifier. It supplies the power to make the "bump" as you say. Sound quality and clarity is better than sheer power. I used to design subwoofer boxes and got a pretty good handle on the slot port design for open cabs and trunk spaces. You'll need to plan it out correctly of you want it to work. What do you have already?
Luck Favours The Prepared
Anticanman is offline
post #3 of 8 Old 09-18-2012, 12:12 AM
Opihi59
from here it gets rough
Opihi59's Avatar
There is a complete Electrical, audio, GPS and 2 way radio sub forum to Jeepforum. Here is the link. Ask them for ideas.
http://www.jeepforum.com/forum/f20/
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #4 of 8 Old 09-18-2012, 12:23 AM
Carlos14
I learn something new about you every day...
And to the OP I say just get a simple 10" kicker from best buy that fits behind the rear seat and an amp that's around 300watts and a wiring kit from Walmart. I had the same set up on mine with a 400watt amp around $220 complete.
Carlos14 is offline
post #5 of 8 Old 09-18-2012, 12:34 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
A quick search turned this up
http://www.jeepforum.com/forum/f20/s...-seat-1104073/
post #6 of 8 Old 09-18-2012, 08:59 AM
Carlos14
That's, awesome!
Carlos14 is offline
post #7 of 8 Old 09-18-2012, 12:53 PM
Kuntryboy816
Kuntryboy816's Avatar
Look up "SirGCal" on here or Google. He's a Mod on here (JF) I believe. He designed a sub box that functions as your rear seat. I got an old YJ rear bench for $10 and plan on converting mine into a single 12" box. Right now I'm running a cheapo sub box from Walmart and a Sony 2 channel amp (1000w) for all 4 speakers and sub. Sounds good at the moment but the box is a PIA to work around and had to add spacers between it and the tailgate for it to work.
Originally Posted by 14Sport View Post
Until you know exactly what is underneath the, well, not really sure what to call them...mistakes...it's hard to come up with a plan of action.
Kuntryboy816 is online now
post #8 of 8 Old 09-18-2012, 04:21 PM
Rproject
1987 YJ Wrangler
I picked up a used 10" box designed for pickup trucks and small cars for $40 at a local Facebook garage sale site. It came with a pair of 300W 10's and horn style tweeters. Picked up a decent, used, 1000W amp for $50 from Craigslist and a $60 wiring harness from Wal-Mart. $150 and a morning's labor and they can hear me coming a block away.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
audio , electronics , radio , subwoffer
Help-question on Grade 8 bolts and exhaust system 77midget TJ Wrangler Technical Forum 45 10-25-2011 04:01 PM
New Sound System: 6 1/2 speakers in sound bar?? Tips please mrbriteside1465 YJ Wrangler Technical Forum 2 11-08-2010 02:32 PM
cheap upgrades for Dana 35, how's this sound? viperbluelx TJ Wrangler Technical Forum 8 06-19-2010 01:02 AM
Cheap exhaust system? vtx531 TJ Wrangler Technical Forum 17 09-14-2009 10:19 AM
Infinity Sound System...how does it sound? otizzy JK Wrangler Technical Forum 16 03-11-2007 11:56 PM
