I want to put 40 inch tires on my yj - Page 2 - JeepForum.com
View Poll Results: which axles should I get
dana 30-ford 8.8 4 7.84%
dana 44s 2 3.92%
dana 60s 45 88.24%
Multiple Choice Poll. Voters: 51. You may not vote on this poll
post #16 of 26 Old 05-04-2011, 10:10 AM
sebastian22
any plans on upgrading to a real engine?
95 Black YJ
sebastian22 is offline
post #17 of 26 Old 05-04-2011, 11:28 AM Thread Starter
kurtis1971
yup got a 350 nv4500 atlas
kurtis1971 is offline
post #18 of 26 Old 05-04-2011, 11:56 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
I am starting to think this is the beginning of a build thread and not a real question.
if you got this...350 nv4500 atlas ... you know you need some Tons.
where are you in PA?
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #19 of 26 Old 05-04-2011, 11:59 AM Thread Starter
kurtis1971
near johnstown been collecting parts all winter. trying to match well so i dont have to do it again.
post #20 of 26 Old 05-04-2011, 12:16 PM
chupacabrah
chupacabrah's Avatar
definitely 1 tons or better, anything else would be a waste of money.
I'm only doing 37s and I have d60/14b
-Jon
'93 YJ with 1 ton SOA in progress (slowly).
chupacabrah is offline
post #21 of 26 Old 05-04-2011, 12:24 PM
MudWrangler
Hey Kurtis!!! You don't happen to want to add any hydrogen to that Jeep to get it to **** and get do ya!!??
You know who this is??????
MudWrangler is offline
post #22 of 26 Old 05-04-2011, 12:56 PM Thread Starter
kurtis1971
hi bry, how have you been?
its in the works but it will be a dry cell that is under pressure, wanna ride with me on some tough trails, lol.
post #23 of 26 Old 05-04-2011, 04:54 PM
1998zj
60/14
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #24 of 26 Old 05-04-2011, 07:04 PM
crockett07
1992 XJ Cherokee
ive got 38s and my plans are d60s and 5.13 gears
crockett07 is offline
post #25 of 26 Old 05-04-2011, 08:12 PM
highrolrcustoms
well if you wheel hard.....you will need a dana 60 front with chromo axles and ctm joints..ect rear dana 70 or sterling 10.25
95 yj juggy, backhalfed, 3 link front with 16" fox dual rate remote resi coilovers, 4 link rear with 16" fox air shocks, Monster Stak 2 Speed transfer case 4.33:1, full width ford 78/79 dana 60hp front axle with 538 gears and full spool, ford sterling 10.25 full width rear axle with 538 gears welded and disc brake conversion, 42x15 swamper tsl's on 15x8 Allied wheels 3.5" backspacing with DIY beadlocks, High Steer with 1.5x.250 dom tubing, Full Hydro steering, custom cage, rci 2161a fuel cell ,smitty xrc 8 winch, cv driveshaft, jk motor mount lift, racing seats with simpson 5 point harnesses
"THE MORE YA PLAY WITH IT.....THE BIGGER IT GETS"
highrolrcustoms is offline
post #26 of 26 Old 05-04-2011, 09:14 PM
915kingwrangler
Dana 60 one ton, and 14 bolt in back, offroad it hard with stock axles and you will fall into a nightmare, dana 44s dana 30 and 35 arent able to handle these offroading, you can get away with street driving but that is about it, save the trouble man and go with either 60s and or 14 bolt for the back..
915kingwrangler is offline
2 inch lift and 32 inch tires orangetj05 TJ Wrangler Technical Forum 17 07-29-2010 02:51 AM
psi for 35 inch tires inglisleslie TJ Wrangler Technical Forum 8 06-26-2010 07:55 AM
2 inch spacers on ravines and 30 inch tires wrangler10 TJ Wrangler Technical Forum 4 10-12-2009 09:44 PM
What tires size tires are you running on a 3 inch lift afaletto YJ Wrangler Technical Forum 8 07-01-2009 01:04 PM
33 inch tires on a 4 cyl. junderwood TJ Wrangler Technical Forum 7 11-05-2004 11:21 AM
