I want to put 40 inch tires on my yj - JeepForum.com
View Poll Results: which axles should I get
dana 30-ford 8.8 4 7.84%
dana 44s 2 3.92%
dana 60s 45 88.24%
Multiple Choice Poll. Voters: 51. You may not vote on this poll
post #1 of 26 Old 05-04-2011, 09:38 AM Thread Starter
kurtis1971
I need to upgrade axles.
kurtis1971 is offline
post #2 of 26 Old 05-04-2011, 10:00 AM
kelti819
ok...what info do you want?
kelti819 is offline
post #3 of 26 Old 05-04-2011, 10:01 AM
Destr0
60s would be the way to go. D30/8.8 or dual D44s will just tear themselves apart unless you just want 40s for looks and will never wheel it. And with gas prices what they are going 40s for looks is not very smart.
1994 Jeep YJ off road toy
1981 CJ7 SBC 350
2005 KJ Libertyt 4x4 CRD w/ 2.5" Frankenlift DD
Destr0 is offline
post #4 of 26 Old 05-04-2011, 10:03 AM
Louie4
"You pass butter"
Louie4's Avatar
I see no point in putting 40's on anything less than a D60 but that's me. Also, if you can afford the 40's go for the gold and build 60's.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #5 of 26 Old 05-04-2011, 10:09 AM Thread Starter
kurtis1971
I keep thinking just do the 60s so I dont have to keep upgrading, but wanted more input.
post #6 of 26 Old 05-04-2011, 10:13 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
60 front
sterling 10.25, 14 bolt, or Dana 70 rear
A dana 60 is a 3/4 ton rear, you want a one ton rear for 40's. Search, you will find people that chew up rear stock 60's on 40's. You can make a 60 plenty strong with chromo shafts, high end gears, and a strong locker.... but a $200 one ton rear is stronger and cheaper.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #7 of 26 Old 05-04-2011, 10:14 AM
MightyLampshade
1979 CJ7
If you're really going right to 40s then get then go right to 60s. The time, effort and money you'd have to sink into anything else and still come out with a likely weaker axle make them pretty much the right option as far as I see things.
Originally Posted by Keith
Let's make fun of him for being assaulted by chicken so he can claim emotional distress.
MightyLampshade is offline
post #8 of 26 Old 05-04-2011, 10:24 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Have you thought about the wheel base stretch and what suspension you want to run?
Poke is offline
post #9 of 26 Old 05-04-2011, 10:32 AM Thread Starter
kurtis1971
yup i got dakota springs in the rear and waggy springs up front, with astro steering box.
post #10 of 26 Old 05-04-2011, 10:36 AM
Xpress
Pffft, don't listen to these nay sayers. The D30/D35's will be fine
Xpress is offline
post #11 of 26 Old 05-04-2011, 10:37 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Poke is offline
post #12 of 26 Old 05-04-2011, 10:45 AM
JFcavedweller
nothing smaller than a 60...
O|||||||O - '99 TJ
■|||||||■ - '97 ZJ
JFcavedweller is offline
post #13 of 26 Old 05-04-2011, 10:56 AM
SirChiefton
I havent much to add to this except a story...I almost traded a guy for a '88 with 46's under it. It was sillly high, had a stirrup you used to get in it. He had them bolted to the stock axles running 4.10's. I laughed at him when I saw both spring perches broken, u-joints about to fall out and a list of other stuff about to fail. The body was immaculate though.
He said he thought it needed a clutch...
SirChiefton is offline
post #14 of 26 Old 05-04-2011, 11:04 AM
JFcavedweller
tell me you have a pic somewhere? and i'll bet he was right about it needing a new clutch :P
O|||||||O - '99 TJ
■|||||||■ - '97 ZJ
post #15 of 26 Old 05-04-2011, 11:06 AM
Bojeepus
dana 60 portals!
Bojeepus is offline
2 inch lift and 32 inch tires orangetj05 TJ Wrangler Technical Forum 17 07-29-2010 03:51 AM
psi for 35 inch tires inglisleslie TJ Wrangler Technical Forum 8 06-26-2010 08:55 AM
2 inch spacers on ravines and 30 inch tires wrangler10 TJ Wrangler Technical Forum 4 10-12-2009 10:44 PM
What tires size tires are you running on a 3 inch lift afaletto YJ Wrangler Technical Forum 8 07-01-2009 02:04 PM
33 inch tires on a 4 cyl. junderwood TJ Wrangler Technical Forum 7 11-05-2004 12:21 PM
