I want to build a diesel jeep - Page 2 - JeepForum.com
post #16 of 30 Old 10-05-2006, 10:03 PM
rayar3
If Jeeps could fly...
rayar3's Avatar
Originally Posted by bobbert350
i no that diesel engine dont rev up high at all...they have globs of low end power.. im saying for that kinda of money i would invest it in something else...3k thats alot..u can easily buy a used lt1 motor for that well way less than that...and u will get alot more horses and similar torque..
I know that the diesel engine doesn't rev up very high. The have a lot of low end power. For that kind of money I would invest it into something else. Three thousand is a lot of money. You can easily buy a used LT1 engine (a motor is electric) for that, or even less than that. You will get more horsepower and similar torque.
Sorry. I needed that.
You can have all the HP in the world. Torque will let you climb up a wall.
2000 XJ 2-door (current)
2006 65th Anniversary TJ (sold)
rayar3 is offline
post #17 of 30 Old 10-06-2006, 07:04 AM
speedracer2536
the golen stroker kit has close to 300ft lbs though for 3499 through quadratec you have a motor that will bolt in all else you would need are the injecters which they also sell for 64 bucks a piece
93 yj lifted locked and ready to rock
6.5"soa 35's lockers beadlocks,8.8
and some other junk here and there
if your in austin look them up best guys to deal with hands down
speedracer2536 is offline
post #18 of 30 Old 08-16-2012, 07:22 PM
Homebrewed2
There are alot of good options for a diesel swap. The Cummins 3.9 is a great engine but it is very tall and requires a 4" lift to clear the pan. A cummins 3.3 is a little shorter and can put out 110-120hp 350lb-ft of torque. You might look at the Mercedes diesel also. Look into Phoenix Castings in Nebraksa, they make adapters for the sae bell housings to ford, chevy, jeep and dodge trans.
Homebrewed2 is offline
post #19 of 30 Old 02-03-2013, 08:35 PM
youngjeeper11
youngjeeper11's Avatar
1987 YJ Wrangler
It cracks me up all the assumtions that are still made about this swap.
It is all a matter of opinon and what you want your jeep to do and be capable of, therefore research is the most important thing, but I have done 3 V8 swap into YJs, and the 4BT is the the most fun to drive out of any of them, in my opinon.
Check out my build thread....
http://www.jeepforum.com/forum/f12/4...-pics-1275843/
The 4BT is about 700 lbs, and is capable of way more power and torque than the 4.0 could dream of. The 3.9 Cummins does not put of great power and torque numbers stock, but the great thing about them is the potential RELIABLE power they can make without too much modification.
Jeep 1:Used to have a 93 YJ 2.5l- 3.5" Black Diamond, Chevy TBI 5.7l V8, SM 465 4 speed, 8.8 rear( 4.10, L/S), rhinoline, Mile Marker 9000, NP 231, Had to sell it due to college
Jeep 2: 89/91 YJ, 4BT Cummins, NV4500, NP 231, Old Man Emu 2.5" suspension lift, 1" body lift.....Runs and drives, but very much a project
Interned at Novak Conversions 2 summers ago
Ask me about my 4BT Cummins Motor Mounts!!
youngjeeper11 is offline
post #20 of 30 Old 02-04-2013, 07:37 AM
Que89YJ
X2 with the 4BT. I was just talking about this very swap on the way in this morning. Sweet build Yound Jeeper. How much total do you think it cost you to do the swap?
Que89YJ is offline
post #21 of 30 Old 02-04-2013, 07:41 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
You could just buy this one:
http://charlestonwv.craigslist.org/cto/3462406094.html
-John-
johnboy68 is offline
post #22 of 30 Old 02-04-2013, 09:56 AM
youngjeeper11
1987 YJ Wrangler
I THINK I am around the $6000 dollar range, including the jeep (not including the jeep body I set on fire )
I bought the Jeep without a powertrain for $1400 I think, so I think you should plan on spening at least $4000 on this swap, it all depends how you do it.....
I may be way off, but I prefer to no keep track of how much money I put into this thing haha.
I love that 6.2 YJ! I have been playing with the idea of a Duramax diesel in a Cherokee...
post #23 of 30 Old 02-04-2013, 10:07 AM
Randonexplosion
Deplorable
Randonexplosion's Avatar
I love my Duramax
Randonexplosion is offline
post #24 of 30 Old 02-04-2013, 10:29 AM
MLJeeper
MLJeeper's Avatar
I love my Duramax
Same here, eats LT-1s and pulls a pair of jeeps without issue when asked to do so. Does it all at a nice low RPM. The turbo diesel and a good programmer are just good fun :-)
But as mentioned above, there are a bunch of good choices and it comes down to whats fun for you. Personally, I do not like a diesel on the trail, the vapor gases everyone out and is noisier than I would personally like. I go for peace and quiet as much as I do for fun. There is also the if you run out of fuel no ones going to have any diesel fuel thing to. But I love diesels.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #25 of 30 Old 02-04-2013, 11:02 AM
youngjeeper11
1987 YJ Wrangler
I love my 01 24v cummins, and I dont even have a programmer yet.
One down side of diesel on the trails also is IF you do run out of fuel, its usually really bad on the injection pump, and you will be bleeding lines.... i guess the same situation is possible if you are low on fuel and on a steep incline......but just dont run of of fuel haha....
post #26 of 30 Old 02-04-2013, 11:10 AM
xtremzj
Originally Posted by 90yjkrawler View Post
That 3.9L would be good if you do alot of traveling or you pull a boat or something. But for high revs in a mud hole or alot of crawling, a small block V-8 almost can't be beat. And I doubt you could get 300 lbs of torque out of a stroked 4.0L unless it was sleeved and bored out to a 5.0L.
Ignorant statement is ignorant. I have a Golen 4.7 stroker and am over 300 tq.
Google more, post less.
98 ZJ 5.5in hybrid long arm/35"TSLs/4.7 Golen Stroker/Kevin's front bumper/TrailReady rear/hp30/d44/4.56/oba/dual battery/rocklights/milemarker9k.Way to much to list.
QuirkWorks Sponsored #44 subaru rally car
CHRYSLER CERTIFIED MASTER TECH. PM IF YOU HAVE QUESTIONS.
xtremzj is offline
post #27 of 30 Old 02-05-2013, 07:52 AM
Labhound
There is a write up in the April 2013 issue of JP magazine about swapping diesel engines into Jeeps and about what mpg they would get, some are
into to 30 mpg !!
Labhound is online now
post #28 of 30 Old 02-05-2013, 11:17 AM
Randonexplosion
Deplorable
I don't have a programmer for mine, it's a company truck but I get to use it as a tow rig. I love the torque, but I honestly think my '99 silverado 5.3 was quicker. (I am swapping that engine into my Jeep btw) What year is yours? mine is an '05
Sorry for the hijack OP!
post #29 of 30 Old 02-06-2013, 09:09 AM
MLJeeper
MLJeeper's Avatar
2008 LMM. Ive never had a 5.3 but I had the 6.0 in my last 2500 and its a no contest.
MLJeeper is offline
post #30 of 30 Old 02-06-2013, 09:18 AM
Randonexplosion
Deplorable
I had the 6.0 in my last work truck too. 01 GMC. My Silverado would eat that 6.0 haha
Diesel Jeep? rlacey TJ Wrangler Technical Forum 41 05-24-2007 02:04 PM
jEEP GIVE US THE DIESEL HECK IF THE hUMMER H3 HAD A SMALL DIESEL IT WOULD BE NUMBER 1 4.0v8eater JK Wrangler Technical Forum 22 08-02-2006 12:10 PM
Diesel Jeep austineo TJ Wrangler Technical Forum 39 05-12-2006 11:09 AM
diesel jeep tiayiti YJ Wrangler Technical Forum 7 05-10-2006 10:51 PM
Diesel Jeep volcom3375 YJ Wrangler Technical Forum 6 01-12-2006 09:10 AM
