I want to build a diesel jeep - JeepForum.com
post #1 of 30 Old 10-04-2006, 12:46 PM Thread Starter
myjeepsux420
http://cgi.ebay.com/ebaymotors/Cummi...QQcmdZViewItem
The 3.9L comes in at around 900 lbs. Only about 300 more than a 4.0L I imagine the torque would be near 300 lbs on this motor. No idea where to get a transmission for it, but I would use an atlas II for the t-case. There was a jeep on e-bay a few months ago with this engine in it. I know I'll never actually do this conversion, but it is nice to dream.
1995 YJ Stroked 4.5L I-6 Headders, high flow cat. and exhaust Big Bore Throttle Body, Cold Air intake
Jet Chip Stage 2 plus thermostat
3 1/2 inch lift with 33x12.50 tires
Posi Lock front diff and Ford 8.8
myjeepsux420 is offline
post #2 of 30 Old 10-04-2006, 12:50 PM
tcaz10
inm not gunna lie that would be pretty sick
tcaz10 is offline
post #3 of 30 Old 10-04-2006, 01:00 PM
ddmech
ddmech's Avatar
the 3.9 doesnt weight but about 700 pounds.Iwould be great.Hope to do it myself someday.
95 yj 2.5 supercharged soa 2 inch springs 9ooo lb superwinch custom front bumper and lights
ddmech is offline
post #4 of 30 Old 10-04-2006, 01:10 PM Thread Starter
myjeepsux420
The auction states the engine weighs 900 lbs. I have no experience with this engine, so I have no idea what it actually weighs. If it's only 700 lbs you could leave an YJ front suspension stock.
post #5 of 30 Old 10-04-2006, 09:59 PM
drexelsteve
so nobody's gonna bid?
13 Rubi
drexelsteve is offline
post #6 of 30 Old 10-05-2006, 11:23 AM Thread Starter
myjeepsux420
Sorry, my money tree is dying.
post #7 of 30 Old 10-05-2006, 12:58 PM
bobbert350
bobbert350's Avatar
a 4.0 is better than that diesle...the 4.0 has 170horses that 60 more than that motor and 225 ft/lbs of torque...if i wanted a motor i would go with a chevy 350 or something better
bobbert350 is offline
post #8 of 30 Old 10-05-2006, 12:59 PM
bobbert350
bobbert350's Avatar
for 3k u can buy a used ls1 or lt1 motor....
post #9 of 30 Old 10-05-2006, 01:15 PM
rayar3
If Jeeps could fly...
rayar3's Avatar
Better?
That 3.9L puts out 300 ft./lbs. of torque!!! And I bet it get's better mpg too...
2000 XJ 2-door (current)
2006 65th Anniversary TJ (sold)
rayar3 is offline
post #10 of 30 Old 10-05-2006, 01:20 PM Thread Starter
myjeepsux420
I'll bet the engine is good for around 25 MPG. Way better than my 4.5L for sure. I doubt my engine makes 300 lbs of torque. Besides, a little tuning of the turbo and that thing would fly. I imagine that engine makes all it's torque around 1000 rpm's.
post #11 of 30 Old 10-05-2006, 02:45 PM
HotDogWater
The HP rating is so low only because HP is a function of RPMs... and since diesels don't rev very high their HP ratings are lower.
95 Rio Grande 2.5L -- stock with 30x9.5 ATs
HotDogWater is offline
post #12 of 30 Old 10-05-2006, 08:21 PM
BIGWILL78
BIGWILL78's Avatar
It all depends on what you would use the thing for on which one would be better or not. But yes, the 3.9 is more in the range of 700lbs. If you count all the other things, it could get to 900 quickly, but the engine itself is only about 700. But if you are talking just raw numbers, you could get that much torque out of a stroked 4.0 for about the same money.
BIGWILL78 is offline
post #13 of 30 Old 10-05-2006, 08:35 PM
drexelsteve
but i'd be willing to bet that a stroked 4.0 won't last much past 250,000 miles...
13 Rubi
post #14 of 30 Old 10-05-2006, 09:51 PM
bobbert350
bobbert350's Avatar
i no that diesel engine dont rev up high at all...they have globs of low end power.. im saying for that kinda of money i would invest it in something else...3k thats alot..u can easily buy a used lt1 motor for that well way less than that...and u will get alot more horses and similar torque..
post #15 of 30 Old 10-05-2006, 09:55 PM
90yjkrawler
That 3.9L would be good if you do alot of traveling or you pull a boat or something. But for high revs in a mud hole or alot of crawling, a small block V-8 almost can't be beat. And I doubt you could get 300 lbs of torque out of a stroked 4.0L unless it was sleeved and bored out to a 5.0L.
Until They All Come Home!
90yjkrawler is offline
Diesel Jeep? rlacey TJ Wrangler Technical Forum 41 05-24-2007 02:04 PM
jEEP GIVE US THE DIESEL HECK IF THE hUMMER H3 HAD A SMALL DIESEL IT WOULD BE NUMBER 1 4.0v8eater JK Wrangler Technical Forum 22 08-02-2006 12:10 PM
Diesel Jeep austineo TJ Wrangler Technical Forum 39 05-12-2006 11:09 AM
diesel jeep tiayiti YJ Wrangler Technical Forum 7 05-10-2006 10:51 PM
Diesel Jeep volcom3375 YJ Wrangler Technical Forum 6 01-12-2006 09:10 AM
