I think I did something wrong - Page 2 - JeepForum.com
post #16 of 16 Old 04-04-2002, 09:31 AM
4wheeler4CJ
4wheeler4CJ's Avatar
However, dropping a TC will lessen BOTH ends angles almost equally, not just the TC end. Picture it physically. The only thing that will cause a little bit (and I mean a little bit, LOL) is the "tilting" of the entire drivetrain as you drop the TC. But, figure it out, if you drop the TC an inch or so, the actual tilt angle of your entire drivetrain is not much at all. That amount of tilt angle is the only difference in angle you end up with between your driveshaft ends.
That's why, in most cases, you won't get vibration simply from dropping your TC (unless you drop it significantly, like 2 or 3", but doing it that much usually will cause you engine to hit your firewall, so it's unlikely you'd ever go that much. If you did, that's when you usually have to use shims in the rear axle.
Point is, for most Jeeps out there that are not modified to the extreme, all the technical jargon won't matter, most of us will fall under the ""Perfection" is not required. Minor variations in parallelism are acceptable". <img border="0" title="" alt="[Wink]" src="wink.gif" />
4wheeler4CJ is offline
nutter gone wrong... VERY WRONG, what happened!??! rolledthatho YJ Wrangler Technical Forum 46 03-31-2007 12:45 PM
Tell me I'm WRONG!! ghostwriter YJ Wrangler Technical Forum 14 10-22-2006 03:32 PM
Is this wrong? IResQ TJ Wrangler Technical Forum 3 06-20-2005 05:45 PM
Who's Wrong? MCanavan TJ Wrangler Technical Forum 31 04-13-2005 08:18 PM
wrong spark plug or wrong engine? oldfrt47 YJ Wrangler Technical Forum 1 10-10-2003 05:45 AM
