I read 3 Check Engine Codes - JeepForum.com
post #1 of 3 Old 11-06-2012, 04:10 PM Thread Starter
wranglin5
My Check Engine light came on about a week ago. It came on the first day it got kinda cold like 45 degrees. I let the jeep warm up for like a minute, then went driving. I had to kinda gun it to get through a yellow light and thats when it came on for the first time. My codes read 11 41 and 17. ignition, alternator field, and engine running too cool. when i turn the jeep on the light doesnt come on, but when i get up to like 30 and above is when it comes on and it stays on untill i turn the car off. then when i turn it on again it stays off untill i hit like 30 and up. what do yall think is wrong with it? thanks for any input CORRECTION. i think i read it wrong and it might be 24 Throttle position sensor and 27 fuel injector control. which makes more sense? its on my 92 not my 95 if that helps narrow it down. i got 1 11 1111 1 1 1111111. i think the 2 lone flashes are supposed to be together.
if you can't go no mo, put it in fo low
wranglin5 is offline
post #2 of 3 Old 11-06-2012, 04:29 PM
Opihi59
from here it gets rough
Opihi59's Avatar
I do not feel you are interpreting the flashes correctly. It should always end in a 55 "end of codes." If you're uncertain, post up a vid of your sequence from start to finish and we'll help from there.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #3 of 3 Old 11-06-2012, 05:22 PM Thread Starter
wranglin5
i know i just didnt put the 55 because i knew the 55 meant it was over. the temperature gauge is reading 100, so i guess its busted, would that cause the check engine light to come on?
