I need tans/clutch help!! - JeepForum.com
post #1 of 2 Old 04-02-2010, 11:41 PM Thread Starter
yamahaj34
i was off roading and i got locked out of third gear, then probabally a month later first and secong gear went, im pretty sure there the clutch, is third gear the trans or the sync plate in the clutch??m please help! i need to rebuild
yamahaj34 is offline
post #2 of 2 Old 04-03-2010, 07:48 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Please fill out your profile. Knowing what equipment your Jeep has will greatly affect the accuracy of the advice you can receive here.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
clutch whirrring/squealing noise - but stops when I press on clutch dirtyjpwrangler JK Wrangler Technical Forum 12 09-28-2009 08:55 PM
Why no JK browns or tans? citRon Wrangler General Discussion 30 12-09-2008 01:48 PM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 02:14 PM
Swap '95 for '92 tans.? rwqiii YJ Wrangler Technical Forum 2 04-26-2007 08:20 AM
chevy 350 and th350 tans swap? KizzyRee YJ Wrangler Technical Forum 0 03-02-2005 02:13 PM
