I need super tips for my 87 YJ - JeepForum.com
post #1 of 1 Old 02-16-2012, 02:45 AM Thread Starter
budello
1987 YJ Wrangler
Hi guys
I write from Rome, Italy, so be patience with my english, it's not so good.
My 1987 YJ now has a 258 i6, tf999 transmission and np231 transfer case, weber 32/36 carb, nuttered, team rushed.
The engine: smoke a little white and drink a bit of water
The transmission: leaks oil anywhere has a thin crack on the bell starting from the bolt hole on the engine driver side until the transmission pump. Grind nose if I push hard on gas pedal.
The transfer case: having hard time to use in 4HI (jump in neutral itself), leaks a bit of oil, need a sye.
I need tips to make the right choice about the next 3 issue.
1) Engine: i have in my garage a brand new (not rebuilt, brand new!) 258 I6 that I want upgrade with a 4.0 head. I read in the forum all positive feedback about 4.0 head swap. Anyones has negative feedback about it???
2) Transmission:
A ) I have a 89 tf999 for spare, not working but with a good case. I can try to use it to rebuild my tf999. I never do it, but my mechanical skills are good enough to try to do it by myself, but i don't know where buy the right master rebuild kit and the right torque converter, i still not understand if my tf999 has a mechanical lockup or not.
B ) I'm considering to buy in usa a rebuilded tf999 ready to install.
Can you say me a serious rebuilder?
C ) I'm considering too the th350 rebuilded transmission on the novak adapter website with adapter for amc motor and transfer case. what do you think about? Is the th350 really better than tf999?
I'm not considering to get my transmission rebuilded in italy because it will cost me 2000Ä (2600$) without any warranty on the work. Auto transmission are not popular so it's very hard to find a serious automatic transmission repair shop.
3) Transfer case:
A) I have a d300 that works fine and need only new gaskets an seals. I can buy a flip kit and go with it
B) overhaul my 231 and install a sye
I know that if i use different transmission or t-case i need new driveshafts but this in not a problem.
Any other tips are welcome.
What do you do if it is your YJ ????
Thanks in advance at anyone that help me to make the right choice
Marco
budello is offline
Super jeep turning into super pain! Death wobble CLADAWG TJ Wrangler Technical Forum 10 10-06-2011 10:48 AM
Anyone with a 3.5" Super Flex and Super Swamper 33s? Danegerous TJ Wrangler Technical Forum 1 03-14-2009 10:49 PM
Flowmaster super 40 vs super 44 vs Cherry bomb extreme wolfstyle TJ Wrangler Technical Forum 4 04-22-2008 01:00 PM
Superior Super 35 axle and Super 35 Truss? Voodoo1 YJ Wrangler Technical Forum 10 10-24-2006 09:37 AM
Door Removal question, super quick, super easy....only will take a sec... MCTampa YJ Wrangler Technical Forum 17 07-18-2006 01:42 PM
