I need some advice! - JeepForum.com
post #1 of 2 Old 11-15-2010, 02:50 PM Thread Starter
dmack3501
I need some advice!
Okay.....this is what I would like to do:
I have a 1988 Sahara that I have down to the frame & ready to put back together. It had the factory 4.2 with a TF999 3 speed auto transmission, NP 231 transfer case and about 130,000 miles.
Before I took it apart, it was having carb & head gasket issues and hesitated shifting from park to drive.
I also have a totaled 1996 Cherokee XJ with the 4.0 HO and AW4 auto transmission, but it is only a 2WD, and a 1994 YJ with the 2.5 and a 5 speed manual.....both run great with comperable miles.
I was hoping to use the newer 4.0 and AW4 transmission, but I don't think they will jive with my 231 transfer case.
In the end, I just want a reliable daily driver that will also push a little snow in the winter.
Any advice on how I should combine all of this stuff or any part I should stay away from would be very helpful!!!!!
Thanks!
DMACK
dmack3501 is offline
post #2 of 2 Old 11-15-2010, 03:38 PM
TheNewbie
I'd use the 4.0 with the NP321, I think the NP231 that comes with the 2.5 will have to be adapted to work with the 4.0 and it's tranny though.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
cherokee , sahara , wrangler , xj , YJ
Advice on new Tires? (Shock advice) NorthStar TJ Wrangler Technical Forum 8 07-13-2009 06:46 AM
Need some Advice wigs25 YJ Wrangler Technical Forum 5 06-17-2009 10:59 PM
AX-5 advice jeehole YJ Wrangler Technical Forum 15 05-01-2008 02:35 PM
I need your advice! sdlemaster TJ Wrangler Technical Forum 3 05-17-2007 08:06 AM
Need Advice MKIV-T-Rex TJ Wrangler Technical Forum 4 03-16-2007 02:15 PM
