I need pics of thumb throttle mounting on a Carter carb - JeepForum.com
post #1 of 3 Old 07-01-2011, 06:25 PM Thread Starter
RobertJ
1987 YJ Wrangler
Ok so I bought my Teraflex hand throttle today but cannot for the life of me figure out how to mount the cable to any of the linkages on my Carter Carb. Need some help here guys! Thanks a bunch!
Robert Jordan
GenRight Off Road
Cell: (714) 878-0234
RobertJ is offline
post #2 of 3 Old 07-02-2011, 01:00 AM
89yjsahara258
Not sure if the 87 has it but on my 89 linkage there is another mounting tab for cruise control underneath the accelerator tab that could be used for hand throttle.
89yjsahara258 is offline
post #3 of 3 Old 07-02-2011, 07:21 PM
timatoe
timatoe's Avatar
So here's how I connected mine (home brew). I don't have the Carter anymore, but it's connected to stock bracketry....
This stock bracket has a square hole right here, I welded a tab over it and tapped it to fit a bicycle adjuster fitting to hold the cable and a hose clamp to the heater hose to keep the cable in place.
Then I just ran the loose end down and connected it to the little arm at the bottom of the plate on the inside that has a hole in it. You can see in this pic there's a similar arm on the outside.
Not the most high tech way, but it was easy and it works.
I used a bike brake lever inside...
timatoe is offline
Thumb throttle on what side? jeepster93 YJ Wrangler Technical Forum 15 07-01-2011 03:50 AM
Carter throttle linkage bleached YJ Wrangler Technical Forum 0 05-04-2009 09:51 AM
Carter BBD Carb Pics??? JohnChrist YJ Wrangler Technical Forum 2 09-23-2006 08:06 PM
Different uses for the thumb throttle djaychris TJ Wrangler Technical Forum 29 11-07-2005 06:17 PM
throttle return spring mounting on weber carb cueball YJ Wrangler Technical Forum 0 09-10-2005 07:36 AM
