I need a new NP231 transfer case - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > I need a new NP231 transfer case
Savvy Billet LED Tail LightsLight up the holidays with LED lights from JeepHutIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 09-09-2014, 07:43 PM   #1
Sundodger
So I snapped my rear drive shaft (ok because I wanted to replace it and put in a SYE at the same time) and it did some pretty good damage to my muffler and destroyed my transfer case. I know the PO had just had it rebuilt too. So guys, should I go the used or brand new route and how much should the transfer case run me used and or new?
Sundodger is offline   Reply With Quote Quick reply to this message
Unread 09-10-2014, 01:47 AM   #2
whiteyj1994
what did you break on your tc ? do you have pictures? The 231 is pretty stout, if you broke the tailshaft housing your going to replace it anyway with a SYE kit.
lead foot locker and away we go
whiteyj1994 is offline   Reply With Quote Quick reply to this message
Unread 09-10-2014, 07:19 AM   #3
StanF
New ones are outrageously expensive. Go used - you might be able to find one with an SYE. Or used + rebuild kit + SYE.
My Ammo Can Console: http://www.jeepforum.com/forum/f12/yet-another-ammo-can-project-finished-1498520/
My 8.8 Swap: http://www.jeepforum.com/forum/f12/yet-another-ford-8-8-swap-extras-1565339/
StanF is offline   Reply With Quote Quick reply to this message
Unread 09-10-2014, 08:04 AM   #4
Que89YJ
Used. Car-parts.com or google for Used Jeep parts scrap yards in your area.
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 10-30-2014, 04:22 PM   #5
Sundodger
Sorry for the delayed response, but yes that's exactly what I had done. I was climbing a hill, pulling my trailer with my quad in it and when I down shifted into 3rd the housing (U joint which connects into the rear differential) snapped. So I had to rebuild my transfer case which allowed me to update my gear ratio to 4-1, I put in a SYE and obviously a new drive line. The spinning drive shaft destroyed my exhaust which had been rubbing on my front drive shaft so I had the exhaust completely redone and redirected. While I was at it, I put in a vacuum kit because 4WD wasn't engaging properly. Next up is a front and rear axle upgrade. Probably go D44 in the back but just upgrade the D30 front with a chromolly shaft. Lockers in the front and back and I'll be ready to hit harder trails.
I just put the doors back on, took the soft top off and put my hard top back on which has been sitting for 2 years now.
