I need help with clutch replace - Page 2 - JeepForum.com
post #16 of 43 Old 09-01-2011, 01:06 PM Thread Starter
qewbawl
Originally Posted by tobias94yj
Very true on everything and handle your newly machined flywheel the same way. here is a link to a thread i did about swapping a tranny and installing a new clutch.
That is a great thread. I will deffinitely be referring back to it when installing the tranny and clutch.
Thanks
qewbawl is offline
post #17 of 43 Old 09-01-2011, 01:15 PM
zeus87gn
1987 YJ Wrangler
Here's one type -> http://www.harborfreight.com/15-piec...-set-5469.html
Here's another -> http://www.harborfreight.com/3-jaw-p...ller-4876.html
The one I have is actually a cross between the two.
It has the 3 jaw interior puller head like the second type,
but it has the slide hammer like the first one.
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #18 of 43 Old 09-01-2011, 04:34 PM
oldtime_ironman
Originally Posted by qewbawl View Post
I actually have a Haynes repair manual but is so old its hard to make out some of the instructions. I'm looking at buying a Helm Inc. repair manual.
What exactly is a stud and where can I get one?
Thanks.
Studs are simple. Just get 2 bolts about 4 inches long. The same size thread as the ones that go from the bellhousing into the engine block. Cut the heads off them and round over the cut-off ends a bit. Plain old hardware store bolts are fine for this.
To use the studs, just finger-tight screw them into the engine block either on the sides or up top where the bellhousing goes. They're just temporary to help you get all the bolt holes lined up. Once you have all the other bolts started, you unscrew the studs back out, and put the normal bolts back in where they were.
oldtime_ironman is offline
post #19 of 43 Old 09-01-2011, 05:35 PM Thread Starter
qewbawl
Sweet! Thanks for the tip! Which one of the two you listed would you recommend?
qewbawl is offline
post #20 of 43 Old 09-01-2011, 05:36 PM Thread Starter
qewbawl
I see. Thanks for clarifying that up for me. It definitely sounds like it would make the installation process easier.
Thanks again.
qewbawl is offline
post #21 of 43 Old 09-01-2011, 05:40 PM
oldtime_ironman
I recommend trying the grease trick before spending on a puller for the pilot bearing. Just pack the hole in the pilot with grease. Stick a 1/2 inch bolt in it and whap it sharply with a hammer. Worked for me every time. Just use a bolt that fits the hole pretty close.
If it doesn't work for some reason, then yeah a slide-hammer puller will.
post #22 of 43 Old 09-01-2011, 05:54 PM
Newk76
We rented a bearing remover from the local parts store. Tried all the other tricks first, nothing worked. The rental was expensive, but as long as you return the tool you get your money back.. at least where we rented from. Good luck!
Newk76 is offline
post #23 of 43 Old 09-01-2011, 07:24 PM
ejeeperguy
1982 CJ7
Okay you guys never tried using the old grease trick to get the bearing out! Load the hole up take a long socket I think it was a 1/2 in and a old 3inch extension.Put the socket on backwards down the extension shaft.what this does is seal the end of the socket .put it in the bearing then quick hard hits you might have to repack it once or twice but it will pop out.It works, I was shocked when I first saw this years ago.Autozone has the clutch kits they have the best prices for it ,and the bearing come with it.Get the one with the slave cylinder too while you are in there.I just did all this to my wife's 90 YJ last year .I would also change the line and master cylinder too my friend you will thank me later. they will go on you. the new pressure plate will make the old parts pop a seal.
Happy Wheelling
ejeeperguy is offline
post #24 of 43 Old 09-01-2011, 07:50 PM Thread Starter
qewbawl
Thanks for the tip!
qewbawl is offline
post #25 of 43 Old 09-01-2011, 07:51 PM Thread Starter
qewbawl
Thanks. I will look around and see what the tool goes for.
qewbawl is offline
post #26 of 43 Old 09-01-2011, 07:53 PM Thread Starter
qewbawl
Happy Wheelling
Yeah, I just purchased the clutch set today from Autozone. It came with the clutch, presure plate, pilot bearing, and release bearing. I will be looking into master slave cylinder.
Thanks!
qewbawl is offline
post #27 of 43 Old 09-02-2011, 07:04 AM
mrbman
Good thread.
The alignment studs are a big help particularly if you are working alone.
One other tip is to check that your clutch disc is oriented properly.
It is usually marked on one surface.
mrbman is offline
post #28 of 43 Old 09-02-2011, 03:53 PM Thread Starter
qewbawl
Originally Posted by mrbman
Good thread.
Thanks to all the people contributing, it has turned out to be a good thread :-)
Thanks for the tip!
qewbawl is offline
post #29 of 43 Old 09-02-2011, 03:57 PM Thread Starter
qewbawl
UPDATE:
I just took the pressure plate, clutch, and flywheel off! When I took the flywheel off, the pilot bearing was still inside so, we just took a socket that would fit inside and pushed it out - it was quite simple. I am on my way to my local machine shop to have the flywheel turned ($30).
Thanks for all the help!
qewbawl is offline
post #30 of 43 Old 09-02-2011, 04:14 PM
stratostix
UPDATE:
Glad to hear everything's going smoothly. Lucky u. $30 to turn ur flywheel? That's a great price. I paid $60 for mine. I had to since it was the only machine shop in town... anyways gl with the remainder of ur repair. Ur over the hump.
stratostix is offline
