i need help!!!!! - JeepForum.com
post #1 of 6 Old 01-27-2015, 05:38 PM Thread Starter
flippinjeep
i need help!!!!!
90 yj with 95 4.0 motor swap
ax15
np231 t case with mega short sye
4.88 gears open diffs
dana 35 rear
dana 30 front
spring over axle lift on 35s
I kept snapping u joints on my rear driveshaft
so I bought a sye and new drive shaft and im still snapping u joints when I go mudding
I thought the sye would fix this issue but it didn't....after looking at my jeep a little bit closer I noticed im getting a lot of axle wrap is there anything I can do to fix this?
add leafs to rear leafsprings?
ladder bar?
new leaf springs?
thanks for the help
flippinjeep is offline
post #2 of 6 Old 01-27-2015, 05:46 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
http://www.ruffstuffspecialties.com/catalog/AWKIT.html
Hope you can weld.
91 YJ "Alice" 4.0L, AX-15, NP 231 w/HnT Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #3 of 6 Old 01-27-2015, 06:44 PM
ghetdjc320
http://www.quadratec.com/products/52237_05X0_PG.htm these can help a bit too, but definitely checkout out the rs link above
-DJC
ghetdjc320 is offline
post #4 of 6 Old 01-28-2015, 09:05 AM
warthog312
Sprung over suspensions generally have axle wrap issues when exposed to high torque situations, doesn't matter if it's a Jeep or an old muscle car; you're going to need a traction/anti-wrap bar. It's pretty easy to make your own, but there are bolt in kits avaliable.
Word of advice though: if you're going through the trouble of fabricating and welding in a traction bar, don't do it to the Dana 35, get yourself an 8.8 in there.
Click for build thread:
- 302//435//20//8.8
>>>the single greatest investment you can make for your jeep is to buy a good welder, and learn how to use it<<<
warthog312 is offline
post #5 of 6 Old 02-02-2015, 01:37 PM Thread Starter
flippinjeep
thanks for the help guys......and a 8.8 swap is in the near feature but im short on cash right now so its one thing at a time
post #6 of 6 Old 02-02-2015, 01:46 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Pics of the rear axle with pinion angle and all please.
Oh, and I may as well have a picture of your steering while we are at it.
Anticanman is offline
