I need heater in my YJ!! - JeepForum.com
post #1 of 11 Old 11-24-2011, 11:51 AM Thread Starter
jeepliker
Well i came to a conclusion that i need heater for my yj cause the winter is coming and im planing to drive it alot. It was somehow taken off when i bought the car. So im asking you guys or whoever knows, what do i need to make this happen? Thanks.
jeepliker is offline
post #2 of 11 Old 11-24-2011, 12:25 PM
915kingwrangler
so they removed the whole assemly, if you have the two hoses, they run together and they are usually next to the battery and valve cover also theyr pretty long, not the radiator hoses still on you might still have the heater core which then you would only need the blower motor, the blower motor goes on the passenger side under the dash, it is an enclosed plastic cover, if you have all this then you have your heater just might be plugged
*** I AM THE PUNISHMENT OF GOD..IF YOU HAD NOT COMMITTED GREAT SINS, GOD WOULD NOT HAVE SENT A PUNISHMENT LIKE ME UPON YOU..***GENGHIS KHAN
915kingwrangler is offline
post #3 of 11 Old 11-24-2011, 12:28 PM Thread Starter
jeepliker
Nope i dont have any. My heater hoses are out and there just 2 holes there. So that is all i need?
post #4 of 11 Old 11-24-2011, 01:04 PM
Xpress
Heater core and the 2 hoses. And to tear the whole dash apart to re-install the new components.
All about that unibody life.
Xpress is offline
post #5 of 11 Old 11-24-2011, 07:15 PM
coleslaw
1987 YJ Wrangler
My lil heater
I took the entire thing out of mine as it was totally shot when I got it. I put at Mojave heater in and works like a charm.
The switch is on the left (Off, low, med, hi) the black and yellow hose goes up to the windshield vent.
[IMG][/IMG]
Passenger side, you can see the hoses. The whole thing is mounted over the tranny well behind the shifter. Give the passanger a lot of leg room. It puts out a lot of heat and volume -140 cfm.
Coleslaw
A country that tries to spend itself to prosperity is like a man standing in a bucket and trying to lift himself by the handles.
Winston Churchill
87 YJ I6, nuttered and rushed, 2.5" lift, 31x10.5, custom made f&r bumpers, Mojave heater, TJ flares, Superwinch S9000, hm swingout tire carrier, tool drawer, custom electical control, and more in the works...........
coleslaw is offline
post #6 of 11 Old 11-24-2011, 07:51 PM
444
Uhh, no. The whole thing can be removed/installed without touching the dash.
444 is offline
post #7 of 11 Old 11-24-2011, 07:54 PM
Xpress
It's part of the dash... gotta remove pieces still
Xpress is offline
post #8 of 11 Old 11-24-2011, 07:57 PM
444
The whole heater box unbolts from the firewall and drops out from under the dash. Unlike a lot of other vehicles I've worked on where you literally have to remove the entire dashboard from the vehicle to get access to the heater box!
444 is offline
post #9 of 11 Old 11-24-2011, 10:05 PM Thread Starter
jeepliker
Anybody know how much the blower motor runs for since thats all i need and just two hose?
post #10 of 11 Old 11-24-2011, 11:14 PM
94chb
i have a parts wrangler and can sell you anything you need but the heater core, you can buy it from the local part store for around 35$ but i have the whole blower and everything. Take pics and post what you do have and we can help ya out.
and if anyone needs a factory a/c unit that goes under the dash let me know, i have one also.
94chb is offline
post #11 of 11 Old 11-25-2011, 05:50 AM
dodger889
Look and see if by chance they left the defroster tube. It will be above the trans hump by the firewall sorta of an oval shaped end, If so then you could get a stock heater box to work. If not then you have a lot more work like taking the dash apart. If that is still there then you do not have to remove the dash to install a stock heater box.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction. blackattak TJ Wrangler Technical Forum 4 02-28-2011 04:20 PM
heater help: not the usual heater problem doug davis TJ Wrangler Technical Forum 2 12-06-2010 05:34 AM
Reverse heater lines at intake 4.2 (front to heater core/ rear to bypass port) Chris Aunchman YJ Wrangler Technical Forum 1 07-27-2010 01:16 PM
YJ Heater Core and Heater Motor Replacement?? Boston Mangler YJ Wrangler Technical Forum 11 11-29-2009 08:31 AM
Heater ? allmopar YJ Wrangler Technical Forum 1 01-30-2007 04:53 PM
