I may have blown my 5th gear...please help - Page 2 - JeepForum.com
post #16 of 17 Old 06-06-2012, 12:13 PM Thread Starter
mrbriteside1465
Took her to a transmission shop today, and they think I have chipped a few teeth off of my 5th gear, possibly my 1st gear as well, and my clutch needs to be replaced. estimated around $1500. I don't even have $500 right now, SO it looks like I'll be checking around junkyards for an AX-15 to swap in. Its either that or try to rebuild the one I have now. Swapping sounds simpler. I just need to make sure the one I get isnt messed up as well.
mrbriteside1465 is offline
post #17 of 17 Old 06-06-2012, 12:54 PM
Opihi59
from here it gets rough
Opihi59's Avatar
If you do get one from a donor vehicle to swap in, look for the large diameter input snout (part that goes into the pilot bearing), yours is most likely 0.750." If you get one that is the internal slave version, you can swap your front input bearing retainer from yours and put it on the "new" trans. Replace the input seal though first, $7 well spent. You can use an AX15 from an XJ/Cherokee as well, but would need to re drill your rear case to clock the transfer case to the correct angle, or swap tail sections from your old trans, and swap in your shifter as well.
This is prolly the cheapest route to go if you aren't anticipating doing your own rebuild.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
5th gear , transfer case , transmission , YJ
Help... Blown 258 I-6 Tuffy1 YJ Wrangler Technical Forum 36 10-30-2011 06:16 PM
Need help with blown reverse gear cush8124 TJ Wrangler Technical Forum 2 06-12-2010 09:45 PM
Blown head gasket actually a blown motor :( KidFresh TJ Wrangler Technical Forum 8 01-11-2010 09:11 PM
4.0 blown, what next? freshlikefruit TJ Wrangler Technical Forum 3 09-18-2009 09:15 PM
Blown yj 94jeep90 YJ Wrangler Technical Forum 10 09-11-2009 02:28 PM
