I made a hood mount for hi lift jack.
| Rock Krawler Suspension's for BLOW OUT prices!!! | Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com |
#1 | |
Pretty simple, economic, and decent looking I think.
Check it out. ![]() ![]() ![]() clipse
#2 |
" Volkswagen "
Looks good man!
Jeep build up...ONGOING Jeep build up...ONGOING R.I.P. Tow Pig Dually build Rear bumper/spare tire carrier build Track bar bracket fabrication AtoZ cage install/build NeetoCJ was a generous guy and renewed my membership..... Blame him for your troubles! |
#3 |
Can you make those bigger?
#4 |
Sorry, those pics are from my blackberry. I can try to take some higher res pics tomorrow. Shoot I may even pull out my cannon S3 IS and get some decent shots of it. Wither way I will get some better pics.
#5 |
Thanks. How did you make it? Did you just drill holes and mount some metal or did you have to bend that?
#6 |
Got my eye on you.....
Looks to me like it is all angle iron. He just cut and drilled holes.
http://i131.photobucket.com/albums/p...k_banner-1.gif Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08 |
#7 |
I like that better than the rear tire carrier mount I made. I may steal that design!
#8 |
Yes it is Angle iron cut and drilled.
#9 |
The only thing i don't like about mounting mine to the hood was thinking before i did it now i can't rest the hood up against the windshield when i need more room to work under the hood.
I should of mounted it on the rear tire swingaway mount. But yours looks great at least you didn't drill into the hood. Just some simple mounts to the factory hinge mounts....way to go! |
#10 | |
![]() ![]() I mounted it to the back of the hood hinges, followed the same design that you used. I put it on then noticed that the way I had it turned blocked the window pee'ers. So I flipped the brackets and it worked great. ![]() ![]() I like it better than the rear carrier I had built. Less stress on the tire carrier, plus I can get a sweet Skull and Cross Bones tire cover. Now the hundred dollar question..... Where can I find one? |
#11 |
Look really good and I really like the idea. I think I might have to steal that idea as well.
Can you open the hood like that? If I am looking at it right. Did you mount it to the back of the hinge? |
#12 |
I like it, nice and simple and cheap.
Your limited slip differential sucks. |
#13 |
I did mount it on the back side of the hinge. I can still open the hood, about an inch past the prop rod location. If I take the jack off I can get it to be straight up and down.
#14 |
Ok. I was just wondering about that. No big deal really. I was wanting to do this and I didn't know where I wanted to mount it. Where it be on the front of the hinge or the back. Thanks for the reply.
#15 |
good job, I think I might be the next in line to steal your idea if I can find any angle iron in the shop at our farm. Thanks for the idea
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
