Quantcast I made a _____ for my YJ! (post your homemade Jeep stuff here) - Page 46 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > I made a _____ for my YJ! (post your homemade Jeep stuff here)
Old 11-11-2009, 09:26 AM   #676
DiabloYJ
Originally Posted by grnjp88 View Post
I've used it a few times already... Guess I should find some better straps.
Also, I made a mount for my CB using the stock ashtray holder:
I just had to drill out the rivets that hold in the metal ashtray bracket to get it out to make room for the CB. Perfect fit.
All of these projects and more are in my "build" thread:
http://www.jeepforum.com/forum/f22/grnjp88s-93-yj-sahara-827888/
WOW I cannot believe I didn't think of that! I have the exact same CB and I hacked apart my ashtray to make it fit. I cut off the cigarette lighter portion by itself because I didn't want to lose that part and bolted it back in. It definitely looks ghetto compared to that. Now I need to hit up the junkyard and find another one and do it right this time around.
"When Life starts to pass you by..............Downshift"
Then again that used to be my motto until I got the Jeep, now that doesn't even work half of the time.
GD Thread HIJACKERS Member #1
ΜΟΛΩΝ ΛΑΒΕ
-Justin
Originally Posted by 2006Sport View Post
Sometimes I wish I had leaf springs.
DiabloYJ is offline   Reply With Quote
Old 11-11-2009, 10:55 AM   #677
grnjp88
Originally Posted by streetdoc432 View Post
How did you mount the radio in the ashtray slot? I have the same radio, I cut out the ashtray "guts", How do you get it in there and mount the ash tray unit and get to the CB mount? Thanks
I had to install the ashtray/lighter unit first, then mount the CB. If you try to mount it all as one unit, the CB ends up blocking some of the mounting bolts.
1993 Jeep Wrangler Sahara °lllll°
1969 VW Beetle Sedan (O\U|U/O)
grnjp88 is offline   Reply With Quote
Old 11-11-2009, 12:49 PM   #678
95wrangler4life
Mud tuggin!
95wrangler4life's Avatar
Originally Posted by E_ROCK View Post
So let me get this straight, you think it is better to have the hood down with only the windshield rather than the hood up and have both the windshield and hood?????
If you are saying that both are inadequate, what is your suggestion?
Again like stated before, the picture is at a weird angle. You can't really tell that he is or isn't in the path. Or can you tell if we are really are pulling in. I believe when the photo was taken, we were given the winches a slight break. His head was pulled in most of the time just relaying messages to me.
The toyota had grenaded his front pinion before the last climb out. We had to start winching him from the very bottom. The last climb at BV carnage doesn’t screw around as seen in this pictures. Your D35 would break just by looking at this hill.
Neither his or my cable would have been able to reach by going through a snatch. So we pulled with two winches. It work so well, that we kept the set up the same.
whatever man, enjoy your wheeling, i know our group cares and is careful on safety, what would i do, i count 8 people in that pic, so that means there is more than the 2 rigs, wireless winch contoller, snatch to another vehicle and be away from mine, anything on a high risk pull we definatly watch how we do it. Winch at a rest whatever, from the time a load is applied to a winch you should consider that line to be a loaded gun with the safety off, plain and simple. And you really think that the speed at which that line comes when it breaks will be stopped by the hood or anything else, the 2 most dangerous tools we use are winches and hi-lifts, when used correct they are great, but even then, are still dangerous.
But what do i know, few years of hardcore wheelin at paragon, oh and doing their safety there, but im a idiot. A little stop and look around will do you wonders
95YJ 2.5 AX5 NP231 HP30 4.88 and aussie, 8.8 4.88 mini spool, 4" RC, 1.5" Boom shackles, 1" BL, 1" rear stretch, 36 12.5 15 TSL SX's, trimmed front fenders, bedlined exterior, comp cut coming soon!
Build thread: http://www.jeepforum.com/forum/f22/build-thread-dirty-894483/
95wrangler4life is offline   Reply With Quote
Old 11-15-2009, 06:03 PM   #679
Jim93YJ
Jim93YJ's Avatar
Side View Mirrors
I wanted to use the skid row relocation brackets and the new MOPAR side view mirrors. Problem was they did not fit together. Solution ended up being to have a machine shop make up some aluminum adapters that would attach the two. The mirrors have an internal spring which I retained so as to provide some resistance when the through bolt was tightened up. I had to drill a hole through the top of the mirror arm so I can put the bolt through. Works well. I look at the passenger mirror through the windshield when the doors are on.
93YJ 2.5L,AX15,Atlas 4.3:1, 4.56 Gears, Dana 30 w/ Posi-lok,Dana 44 Rear w/ Ox Locker + 99 Explorer Disk Brakes,Tom Woods D. Shafts,1" Body, 2.5" ED RE Lift, 31" Pro Comp M/T's with MT Classic II Wheels, Herculined Inside, Flexalite Fan,4.0L Throttle Body, 20 Gal Tank Conversion,Tuffy Center Console,Warn Front Bumper, Rockhard 4X4 Rear Bumper w/ Tire Carrier,Bestop Extended Flares,AMSoil/Redline In Everything and the List Goes On....
AND...
88YJ 4.2L: Interior and mechanical overhaul including engine replacement, nutter bypass, Weber 34 Carb, and work on a whole bunch of other things to get it back to fine running condition without the emissions control...evap cannister kept functional as well as PCV system, and manifold heater.
Jim93YJ is offline   Reply With Quote
Old 11-15-2009, 06:43 PM   #680
Enkord
Finished wiring my offroad lights, put a couple of switches where the cig lighter used to be, and swapped the ashtray for a power inverter.
Ashtray
http://img23.imageshack.us/img23/650/imag0007o.jpg
Lighting it up
http://img23.imageshack.us/img23/1060/imag0021b.jpg
http://img17.imageshack.us/img17/6671/imag0019ne.jpg
http://img17.imageshack.us/img17/4877/imag0020bc.jpg
I think blizzard driving will be alot more fun now
Enkord is offline   Reply With Quote
Old 11-16-2009, 08:58 PM   #681
Motorcharge
Ron Paul 2012
Motorcharge's Avatar
1987
Ashtray
Lighting it up
Click free .
XJ Non-Tech FAQ | 1/20/2013 The End of an Error | Ron Paul '12
Originally Posted by Thomas Jefferson
If there is one principle more deeply rooted in the mind of every American, it is that we should have nothing to do with conquest.
If you find my post to be good or helpful please take a second to click the "thumbs up" icon near the quote option. Thank you.
Motorcharge is offline   Reply With Quote
Old 11-16-2009, 09:30 PM   #682
Bl4cK_kNiF3
great idea with the switches in the cig lighter spot!
1995 Jeep Wrangler YJ, AMC 242, AX-15, 4" Rough Country Lift Kit, Hunter Green
Green Jeep Club Member #360
Bl4cK_kNiF3 is offline   Reply With Quote
Old 11-17-2009, 05:38 AM   #683
Selafane
Originally Posted by RVApunkROCK View Post
Click free .
sweet, I wanted to see what round off road lights would like with square head lights up close..not bad...i just may not do the cj swap lol
Selafane is offline   Reply With Quote
Old 11-20-2009, 06:55 PM   #684
monsterenergy
has anyone made a homemade fire extinguisher roll bar holder
monsterenergy is offline   Reply With Quote
Old 11-20-2009, 06:58 PM   #685
monsterenergy
Ashtray
Lighting it up
what wats are those lights just 2 of them what kind of altornator do you have on it factory or no? Im looking to get 2 110w lights!
Old 11-20-2009, 07:54 PM   #686
cjapgar
cjapgar's Avatar
i just used a 3 in hose clamp from lowes, works great
_______
/l ,[____],
l---L –[]lllllll[]-
()_)-()_)--o-)_)
Bacon is meat candy!
ΜΟΛΩΝ ΛΑΒΕ!
cjapgar is offline   Reply With Quote
Old 11-22-2009, 12:32 AM   #687
KJFactor
Strated in on home made rear corner protection.
http://www.jeepforum.com/forum/f37/home-made-rear-corner-guard-protection-907538/
-1994 Wrangler: Torn to pieces for upgrades(D44&Ford9,fuel cell,stretched,aluminum it all)
-2003 Liberty
GOD WILL JUDGE OUR ENEMIES...WE'LL ARRANGE THE MEETING
KJFactor is offline   Reply With Quote
Old 11-22-2009, 08:39 PM   #688
Enkord
They are Hella 500's, 55w each I think. Factory alternator, though I need to get a new battery.
Old 12-02-2009, 09:07 PM   #689
Xtremjeep
I made a couple things for security. First a center console. Made if 16 gauge steel and fully welded. Also put ARB switches, dome lights, and i've since put an in cab winch control on it. It's painted with hammered finish, and I had some camo vinyl wrap laying around so I threw that on the top. Sorry about the cell phone pics.
Dont have a good pic of it installed yet. Next I made a rear storage drawer, I tried to make it look as finished off as I could. And also decided to mount my 10" sub and 2 6x9 speakers at an angle right behind the seats. The top and doors are off all summer and it's hard to hear the radio. Now I can hear it no problem.
Let me know what you think.
Xtremjeep is offline   Reply With Quote
Old 12-02-2009, 09:11 PM   #690
Enkord
I've been wanting to make a box like that, what kind of lock did you use? Looks really good
diy jeep mods, do it yourself, homemade
Glock Forum
