I made a _____ for my YJ! (post your homemade Jeep stuff here) - Page 114 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > I made a _____ for my YJ! (post your homemade Jeep stuff here)
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 06-04-2011, 07:53 PM   #1696
bigsquat
FORMELY BIGPIMPIN
bigsquat's Avatar
i bet your combustion chamber is clean as a whistle. should eliminate all carbon.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD: http://www.jeepforum.com/forum/showt...hp?t=613943see
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline   Reply With Quote
Unread 06-04-2011, 08:05 PM   #1697
91BoD
If you would like to PM me with your write up and links to pictures I'd be happy to post.
I've heard of the water vapor injection before but figured it was like the HHO generator.
91BoD is offline   Reply With Quote
Unread 06-04-2011, 08:55 PM   #1698
bigsquat
FORMELY BIGPIMPIN
bigsquat's Avatar
just think of the possibilities, add a little seafoam at times, or even some potpourri to set the mode for that specail date
Unread 06-04-2011, 08:59 PM   #1699
TheNewbie
Originally Posted by Rambo1965 View Post
I am officially a newbie to this site, so I am not allowed to post any pictures yet...sigh. But I bought my own 1990 YJ right off the lot. I have always been unhappy with the 14.7 mpg I was getting, so I recently played around with some old hot rod ideas I remembered from the 80's. For about $20, I made a water vapor injection system. It works off engine vacuum and as strange as it sounds, it does work. I now get a more respectable 18.1 mpg and a wee bit more horsepower for cruising on the highway. Over the winter, I even experimented with switching out the water in the reservoir with some alcohol. Perhaps it wasn't exactly smog legal, but it did give me a lot more power. The alcohol made my MPG's drop since I was having a wee bit too much fun romping on the gas.
Anyway, I am now running straight water and enjoying a few more miles per gallon. If you, or anyone else is at all interested in my injection system, just let me know. I'll send you my specs and you can post them on the board. I'm not so much concerned with getting credit for my idea. I just thought it was fun creating something that actually worked so well.
Scott
If you start a thread on this PM me with a link so I can check it out.
1995 YJ 2.5 - 4” RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
My build thread...
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline   Reply With Quote
Unread 06-04-2011, 10:12 PM   #1700
zeke6785
Love to know about the injection
System. Idk if it would work on a tj though.
2012 Wrangler
35" Pro-Comp Xtreme M/T
2" SkyJacker BB
Smittybilt Stinger
zeke6785 is offline   Reply With Quote
Unread 06-05-2011, 01:59 PM   #1701
Cinchup11
Grenade shifter
I made a grenade 4 wheel shifter for my YJ. It’s not a set screw like the ones you get in the stores. I welded a 3/8 coupling nut to the grenade body so it's a perfect tight fit. Im not sure how to upload the pics cause im not a fan of PB.
Cinchup11 is offline   Reply With Quote
Unread 06-05-2011, 04:26 PM   #1702
Rambo1965
There seems to be a bit of interest in my Water Vapor Injection idea. I will be happy to generate a full on write-up for it. One of the Jeep guys on this forum claimed he would post my mock-up if I sent it to him, so I'll send it all to him tomorrow. With any luck, this can help others as well.
Someone wrote that they think it might not work on a TJ. I disagree. From what I can tell, it should work on any internal combustion engine. I even toyed with the idea of hooking it into my wife's Prius to see if it would bump up the mileage on that as well.
I do feel it's doing a capable job of increasing my cylinder pressure and I can say my spark plugs have never looked cleaner, so it does appear to be having some positive effects.
Please be patient, more to come...
Rambo1965 is offline   Reply With Quote
Unread 06-05-2011, 06:48 PM   #1703
mudcrawler90
Today I made a light mount/ flip up plate holder that bolts onto the back of the fairlead mount. It only took less than 5 hours to do, including paint and wiring the lights up. I also made the front bumper a few months ago.
Having to tow your Jeep down the road with a stock truck is like water skiing naked, its embarrassing, your being pulled by a single line, and it hurts a little but in the end all you can do is look back on it and laugh!
/l , [____],
l------L--[]lllllll[]-_
()_) ()_)==♠=)_)
mudcrawler90 is offline   Reply With Quote
Unread 06-06-2011, 04:40 PM   #1704
91BoD
The thread is up! http://www.jeepforum.com/forum/f176/.../#post11664472
Unread 06-07-2011, 06:13 AM   #1705
Andywear
Congo cage with basket.
The PO put on rear LED lights so I had to cut to fit and drill new holes for the rear brackets.
Used to have a good sig but Mod threated to ban me...
[I]Errrrrrr[/I], Will complain else where - &y
Andywear is offline   Reply With Quote
Unread 06-07-2011, 07:31 PM   #1706
plym49
That Jeep is just screaming for more lights..................
(nice Jeep, BTW)
plym49 is offline   Reply With Quote
Unread 06-14-2011, 01:15 AM   #1707
jclauson
I made an overhead console fitting my cd player, cb, and scanner
before padding
1990 YJ w/ lots of home made sh*t
check it out
http://www.jeepforum.com/forum/f22/hysterias-90-yj-build-1190617/
jclauson is offline   Reply With Quote
Unread 06-16-2011, 09:05 AM   #1708
gryphon
jclauson, that's a really nice design on the overhead console. would you happen to have a write up on the build?
gryphon is offline   Reply With Quote
Unread 06-16-2011, 01:33 PM   #1709
jclauson
http://www.jeepforum.com/forum/f37/o...up-yj-1226898/
check it out
Unread 06-18-2011, 06:30 PM   #1710
Bj95Yj
Made myself a four rod holder. Works like a charm. Uses a bungee cord to secure them in. Bolted it right up to the bumper.
Bj95Yj is offline   Reply With Quote
diy jeep mods , do it yourself , homemade
