I'm at my wits end need some ideas - Page 5 - JeepForum.com
post #61 of 67 Old 10-15-2013, 12:22 PM
zeus87gn
1987 YJ Wrangler
Do you notice any black smoke or smell gas when the engine bogs down?
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #62 of 67 Old 10-15-2013, 12:25 PM
zeus87gn
1987 YJ Wrangler
Originally Posted by DonAltman3 View Post
I do have the OEM style fuel filter and honestly thought that any "extra" pressure would just be returned to the tank in essence the filter itself was regulating.
I used to think the same thing - the needle valve would close (via the float) as needed and the extra fuel would go back to the tank
It didn't work that way
Oh, the carb does have a brass float, right?
zeus87gn is offline
post #63 of 67 Old 10-15-2013, 02:28 PM Thread Starter
DonAltman3
I haven't noticed the smoke or smell... but it is plausible its there.. I have a hard top and have been testing it in the evening once I get off work.. its usually dusk.
I called and have an FPR waiting on me at the local parts store... damn those people love me !
I am also considering trying the GM style ICM or even a factory replacement just to eliminate that as a possibility.. but right now I'm tired of throwing money at the problem. I have a friend going to come over tonight and help look at it.
DonAltman3 is offline
post #64 of 67 Old 10-16-2013, 08:33 AM
Que89YJ
Don, when you did the Nutter did you run the seperate ground for the distributor?
Que89YJ is offline
post #65 of 67 Old 10-20-2013, 08:38 PM Thread Starter
DonAltman3
Update
Good evening all. I think I finally found it. After trying everything it seems lol I ran a long fuel line off a tee into the cab With my pressure guage. While driving I managed to see it drop pressure while it bucked. It got down to almost nothing several times. I think ran another fuel tank in the passenger seat and a new line going to it and tried that again. This time I had a buddy holding the line and away we went.. No problems at all my jeep has never been so strong and driven so well since I've owned the thing. i pretty much confirmed it was in the sending unit pick up tube. Weird it never ran low pressure at idle or in the driveway only while driving it. When I tested it I bypassed the filter under the hood and it ran just fine even at 8 psi without even having a return line hooked up. So.....
I dropped the tank and the sending unit looked great. I noticed the ground goes from the sender to itself. So I will be attaching another ground from the sender bolts to the frame.
What I found was a collapsed filter on the end and the thing looked like pure soot. It was hard and black pretty much 100% stopped up...not sure how it even ran honestly.
I plan to pull it off and then just bolt the sending unit back in the tank without the filter. No reason to clog that up and have to lower the tank again. Much easier to clog an external filter and change it in the future.
I am also going to be draining it all the way and wiping it out.. Of sure how a plastic 20 gallon got this crap inside it but I would imagine if the filter is clogged there is a lot of muck in the bottom of it.
I should know something tommorrow night.... Gosh I hope at was it and not just something else to throw a wrench at. At least now damn near everything bolted on this engine will be new. Thanks again for everyone's help
post #66 of 67 Old 10-20-2013, 08:58 PM
Que89YJ
Fuel pressure! Take a pic. I bet the ethanol is breaking the rubber. We just had a long discussion on a thread about it. Jsawduste and I have both seen the effects.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #67 of 67 Old 11-23-2013, 10:39 PM
42ZER0
so what ended up being the final verdict on your yj acceleration bogging/ stalling issue? I just got a yj from someone for cheap, did the nutter then the carb, mc2100 and same issues as yours had and ive also bought almost everything under the hood at least once and did almost every test you did.. was it the sending unit filter? please please please tell me that fixed the problem lol thanks
42ZER0 is offline
