I love major problems!!!! Guage issue... - JeepForum.com
post #1 of 4 Old 09-17-2011, 05:33 PM Thread Starter
Forsaken_Soul
1987 YJ Wrangler
So I on a whim I decided I wanted to get my factory temp gauge working again. I went down to the local auto parts store and purchased a new probe... I got home, found the location of the old probe, and removed it. turns out that the idiot that put in in before me stripped the hell out of it and the "hole." so now I have a wonderful gaping hole in the head and no way to seal it back up. \
Now my question is, can I just drill and tap new threads and just use a sunpro with the larger probe? Or drill and tap and cap it off and hope there is a better place for a sunpro probe?
I <3 used vehicles....
Forsaken_Soul is offline
post #2 of 4 Old 09-17-2011, 05:35 PM Thread Starter
Forsaken_Soul
1987 YJ Wrangler
btw the OEM system is effed. So aftermarket gauge is the only way to go at this point...
post #3 of 4 Old 09-17-2011, 05:36 PM Thread Starter
Forsaken_Soul
1987 YJ Wrangler
Oh and also, I tried searching and I turned up a few threads but none that helped...
post #4 of 4 Old 09-17-2011, 06:53 PM
ejeeperguy
1982 CJ7
You want to come up for some air there.First I would drill and tap in a larger unit you start drilling in the wrong spot and you will be looking for a a replacement. Second if you wanted to use oem parts a brass bushing will work in the larger hole and just get it to match the thread pattern.Just remember to use some thread seal and not over tighten it yourself.
ejeeperguy is offline
Some sort of major clutch issue! HELP! dirtbike7992 YJ Wrangler Technical Forum 2 02-01-2011 03:11 PM
4" lift/major vibration issue EARLSJK JK Wrangler Technical Forum 4 11-24-2010 07:55 AM
Major Steering Issue Hellbound13 JK Wrangler Technical Forum 26 09-29-2009 01:28 PM
2.5L TJ Tranny major issue MacDuffer99 TJ Wrangler Technical Forum 2 05-31-2009 11:15 PM
Major condensation issue!! Quentin_T JK Wrangler Technical Forum 12 12-19-2007 12:13 PM
