I learned that you DO need your front trackbar! - Page 4 - JeepForum.com
post #46 of 48 Old 10-19-2007, 09:21 AM
grenMEG
3 pages WOW
So why did it take three pages to explain that a trac bar on a leaf sprung vehicle, that is not going to be towing, nor if used properly will not be taking any highspeed manuevers. Deliver almost the same amount of on-road performance has if it had one. Though has its benefits of more articulation in OH situations.
If you take your trac bar off it will not allow you front axle to move side to side, it is probably your shackles or your leaf spring center pins.
Also about the telescoping trac-bar. I know it looks like a good idea and i have no exp. on the product, but couldn't you just make a Quick disconnect system for the trac bar instead of throwing down...?$150? Would a long travel shock work? maybe an adjustable one? i was thinking about ways to create less wheel up in my rear since it is so light! (29's, 4 in. lft, and no trac bar) So i was thinking about a long travel shock but i just don't how well it would really stand up, ya know!!?
That and since i am ripping that crap axle out and putting in a new one with 35 in rubbers on it, and relocating the shocks, i think i will test before making another project.
grenMEG is offline
post #47 of 48 Old 10-19-2007, 12:37 PM
flame0086
Originally Posted by 91yjwrangler6
Anybody got a Ford Super duty? Look under the front end, you WILL see a track bar.
Ever seen a 95 dodge cummins rear end? its got sway bars.
and a **** load more torque than your jeep will ever need.
100 mpg!! Western Washington Univeristy X-Prize Team
Support Search and Rescue
Get Lost
flame0086 is offline
post #48 of 48 Old 10-19-2007, 06:38 PM
Ryno98
The problem with a disconnect or long shock is the whole thing about keeping the drag link and track bar in parallel to eliminate bump steer. The stock track bar is a fixed-length bar; therefore if you have a lifted jeep you have to use track-bar relocator brackets to keep things in line which still only gets "close" to parallel. Good luck with that especially if you have a custom or frankenstein lift. Since the telescoping track bar can lengthen or shorten and be tightened at any position, it can be exactly parallel with the drag link at almost any lift height below 6" or so. I had ridiculous scary bump steer at high speeds with no track bar, problem solved with very little headache or install time after the telescoping bar.
1994 YJ, 4.0, auto, only 63K miles, RE 2.5" XD w/ OME shocks, discos, JKS telescoping trackbar, Creager 15X8 soft 8's (4" BS), BFG MT KM 31X10.5X15, SRC Front/Rear bumpers w/ tire carrier
Ryno98 is offline
Front trackbar relocation by drill and rear trackbar relocation bracket install? loudog3114 TJ Wrangler Technical Forum 20 10-26-2014 07:01 PM
Front trackbar vs Adj LCA? Houndx TJ Wrangler Technical Forum 0 01-13-2010 06:55 PM
Adj. Front Trackbar Help Tcormier106 TJ Wrangler Technical Forum 15 08-05-2009 01:50 PM
front trackbar what is best RE,JKS....... jeepfunatic TJ Wrangler Technical Forum 1 10-05-2005 03:58 PM
front trackbar dejablu311 TJ Wrangler Technical Forum 12 11-08-2002 01:52 PM
