I learned that you DO need your front trackbar! - Page 2 - JeepForum.com
post #16 of 48 Old 10-11-2007, 08:58 AM
GrimJeeper91
GrimJeeper91's Avatar
Originally Posted by The Rat
Am I missing something? For your axle to be a couple inches out of line with the rear wouldn't the spring perches and U-bolts have to be in the wrong place? Leaf springs don't flex side to side so how in the world are your springs centered while your axle isn't?
His shackles would be at a pretty good side to side angle...
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline
post #17 of 48 Old 10-11-2007, 08:59 AM
Michael_94YJ
Well, they can move a little bit, which is what the trackbar is supposed to inhibit the axles from doing. A couple inches or more is extreme though. Could be that the rear is out a little one way and the front is offset a little the other making it appear to be out a couple of inches. But yes i agree, if they are out a couple of inches i would tend to think something is loose or worn... JMO
-Michael
1994 YJ 4.0L 5 spd.
flowmaster,15x12 wheels & 35x15 TSLs, sway bar discos, 3.5" leaves SOA + shackles, 2" body lift, JB steering bracket, SYE, M.O.R.E. anti-wrap bar, Bilsteins 5125s up front & BDS Hydros out back, axles in the works
Michael_94YJ is offline
post #18 of 48 Old 10-11-2007, 09:20 AM
bamato
bamato's Avatar
Maybe someones u-bolts are a bit loose??
/l , [____],
l---L--?lllllll?-
()_) ()_)----)_)
Mud is your Friend :)
Tread Lightly
Please help keep our trails clean for future generations to enjoy outdoor recreation as well!
bamato is offline
post #19 of 48 Old 10-11-2007, 09:38 AM
grenMEG
X2, that and i bet since you got a lift you got a hi-lift jack...
Well take that jack and jack up the front to see if the axle "pops" back in to position if not see what you can do. maybe move it side to side, see how it droops, etc...
It might be your shackles, if they are grease shackles and you have the bolts REALLY loose that might create that much side to side movement. Check your spring packs, and maybe your ?wheels???
grenMEG is offline
post #20 of 48 Old 10-11-2007, 09:42 AM
The Rat
-Michael
The track bar inhibits front to back motion. Say your leaf spring snaps on the trail and you aren't running a track bar, your axle won't shift from side to side but it will shift front to back (on the broken side). Seen that scenario in person man...no other issues even after trying to continue wheeling and driving it off the trail...new spring and all was right with the world.
OH WAIT. WHAT?
The Rat is offline
post #21 of 48 Old 10-11-2007, 09:58 AM
Michael_94YJ
not trying to argue here but your track bar inhibits side to side motion, not front to back. Think about it...
1994 YJ 4.0L 5 spd.
post #22 of 48 Old 10-11-2007, 10:00 AM
Michael_94YJ
radius arms on a coil spring rig would inhibit front to back motion.
your leaf springs on a leaf sprung vehicle shouldn't allow your axle to move front to back with or without a track bar.
1994 YJ 4.0L 5 spd.
post #23 of 48 Old 10-11-2007, 10:22 AM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
correct.
i run no track bars, and run an extremely soft leaf spring (old man emu) and the axles are perfectly inline, but then again, i welded them and not jeep.....think my measuring skills are a little more precise than the average assembly line...
if i turn the steering hard to one side, it will flex the leaf springs and shackles a little. bend the frame? no way, been there and done that, if your steering is moving the frame, as was the case with my old frame, you need a new frame bud!
if ye want the tighter feeling ride onroad, put a trac bar on there. i can rest 1 finger on my steering wheel at 70mph and have no vibes/wobbles/etc, and when i turn the steering wheel, the jeep turns...amazing huh?
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #24 of 48 Old 10-11-2007, 10:24 AM
bamato
bamato's Avatar
That is correct, a track bar is there to inhibit side to side movement. Man if I had a dollar for every time I heard this thread come up
/l , [____],
l---L--?lllllll?-
()_) ()_)----)_)
Tread Lightly
bamato is offline
post #25 of 48 Old 10-11-2007, 10:49 AM Thread Starter
dmcanally
dmcanally's Avatar
2011 JK Wrangler
I'm going to have to wait for my girlfriend to get home before I can post a video... but I will take some pictures.
I don't have any vibes or really any problems aside from the axles being out of line and the entire front end of my rig moving when turning at a complete stop.
Red Jeep Club # 383
, _____
/l
,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
dmcanally is offline
post #26 of 48 Old 10-11-2007, 10:54 AM
mp3coupe
mp3coupe's Avatar
Originally Posted by goatboy
Well, all I can tell ya is that there have been leaf sprung vehicles on American roads for over a hundred years without track bars, and not too many manufacturers have seen fit to install them... and there have been tons of guys who have removed them without consequence...if yer springs are displaced one side to another, check your frame...it's probably bent...
Pretty much any truck with leaf springs that wasn't built in the early 80s has a track bar. (Super dutys run them even with the heavy duty springs) They must have realized that a higher center of gravity along with the weight is enough to walk an axle. If you remove your trackbar and go on a twisty road doing the speed limit you can feel the front end walking out. Sure you can remove it and enjoy a soft feeling suspension. I've done it in the past but I experienced the same as the OP and I don't care for the loose feel when cornering. Sure a jeep isn't a sports car but does that mean it needs to float around the turn? The more ark you have in your springs the more you'll feel it (leverage) Even with flat springs there is movement don't kid yourself.
mp3coupe is offline
post #27 of 48 Old 10-11-2007, 12:15 PM
kmax
2006 XK Commander
The picture in Joe's post (#4) looks like it was taken in my garage. Same toolbox, same blue trash can, same parts in the can... Are those old JKS disconnects on that sway bar?
I think when there's no lift and the springs are relatively flat, a track bar will help the front end feel a little tighter. When you add positive arch lift springs and cause the track bar to be at an angle, you create the problem of having components that are trying to move against each other when the springs compress. As was stated in an earlier post, the leaf springs are trying to move vertically, such as over expansion joints on the highway. The track bar, which is now at an angle because of the lift, is trying to move in a radius around the frame mount. Therefore, when the suspension compresses, the track bar causes the springs to deflect to the side, even if just a little bit. My point is, when I had a track bar on there, my jeep felt like it was moving sideways every time I hit a bump that caused compression in the front end. Might be personal preference, but the handling feels better to me without the track bar.
Ken
'06 Commander Ltd, Hemi, QDII, 4" Superlift, Deaver Coils, 285 KM2's on Moabs
kmax is offline
post #28 of 48 Old 10-11-2007, 12:46 PM
s68139c
No sway bar, no track bars, no problems.
s68139c is offline
post #29 of 48 Old 10-11-2007, 04:17 PM
yjrush
x2
I had mine on when I got her. I took it out once, was told by 3 people i didnt need em. Havent had them on since and no problems.
1993 YJ 2.5L, 3.5 BDS lift kit, 1" BDS Shackles, 1" BL, 33' Trxsus MT, Tabor 9K, 4.88 gears, Dana44 Spooled, chromoly in D30 with Lockrite, more to come...
2000 Dodge Ram Quad Cab 5.9L (Tow Rig)
yjrush is offline
post #30 of 48 Old 10-11-2007, 04:25 PM
BadAddetude
Anybody got a Ford Super duty? Look under the front end, you WILL see a track bar. I had mine off when the bracket was broken, and i did not like the way the jeep rode. driving behind it, you could see the rear axel shift from side to side in a corner. lot of torque on those ubolts in corners. my vote is they were there for a reason. Yes, lots of heavy trucks dont have them, but it definatley wouldnt hurt to have it.
1995 YJ: 4.0, 700R4, 231 C/J case, TeraFlex SS SYE/CV shaft, 8.8 with 3.73 gears, 136 Amp Alternator, Trans Cooler, Pavement Ends Flip-top/H-T, 2'' BDS Suspension Lift, MORE 5/8' Greasables, Sony GT-210 Xplode Head.
Under the Knife! See the build thread:
BadAddetude is offline
Front trackbar relocation by drill and rear trackbar relocation bracket install? loudog3114 TJ Wrangler Technical Forum 20 10-26-2014 08:01 PM
Front trackbar vs Adj LCA? Houndx TJ Wrangler Technical Forum 0 01-13-2010 07:55 PM
Adj. Front Trackbar Help Tcormier106 TJ Wrangler Technical Forum 15 08-05-2009 02:50 PM
front trackbar what is best RE,JKS....... jeepfunatic TJ Wrangler Technical Forum 1 10-05-2005 04:58 PM
front trackbar dejablu311 TJ Wrangler Technical Forum 12 11-08-2002 02:52 PM
