I know, another one: will 33x12.5s fit? - JeepForum.com
post #1 of 3 Old 02-17-2009, 04:06 PM Thread Starter
impboy65
I have a 2" shackle lift (for now till the rc lift this summer) and a 1" daystar body lift and a set of smittybilt 6" pocket style flares. Can I fit 33x12.5s? I measured a radius of 17" for good measure and I think I can. I have about a .5 to an inch clearance from that measurment. And the tires I plan to buy are actually 32.8" My rocker height is 19 and 3/4. I know I won't be able to flex at all, but will I rub on turns? This would be temporary untill my 4" rc lift around may hopefully. Thanks
01 TJ stock for now! OlllllllO
impboy65 is offline
post #2 of 3 Old 02-17-2009, 04:14 PM
oompaloompasc3
i think you need a total of 4 inches to be clear with no problems... I dont think you should have a problem from what i see.
1994 Jeep Wrangler SE 4.0 manual, AEM Brute Force Cold Air Intake, Red Optima, Banks Chip, Banks Header, Custom Downpipe, Flowmaster 50 Series, 35x12.50.15 BFG All Terrains, Black Steel Wheels with Simulated Beadlock, 3" Rancho Suspension, 3" BL, 3/4" brandon_yj Shackles, Line-X everywhere, So much more to do....
oompaloompasc3 is offline
post #3 of 3 Old 02-17-2009, 04:26 PM
texas_yj
from my exp. your biggest obsticles will be the tires hitting the fenders on bumps, but you can drive like a low rider till the lift comes, and worse, you need at 4.5" backspacing or you will hit the springs while turning, the stock rims are 5" and 5.5" for the aluminiums and will rub quite bad (as mine do now.....39.99 summit racing cure coming (soft 8s))
Sold) 94 YJ, 4.0L 5 sp manual, Hard top, 33/12.50s, 4.10 ring&pinions, Polished D30 w/Aussie front, 8.8 rear w/ LS, 2.5" RC, 2" BL, 5/8" booms, TJ flares, SYE, custom F/R bumpers and rock sliders, 8k winch, dual optimas, HO alt.
2) (Sold) 99 TJ, mustang 5.0 GT 40, AX15/231J, trektop, 37x12.50r17 cooper STT, superlift 6" long arm, D30/44 w/ ARBs & yukons, customized warn bumpers, custom sliders, 12K winch w/ synthetic rope, custom paint
3) 2007 JKU being built now
texas_yj is offline
2.5L with 4.11 and 33x12.5? iceman123187 TJ Wrangler Technical Forum 21 04-14-2008 06:26 AM
33x12.50 - What PSI do you run?? bman9089 TJ Wrangler Technical Forum 21 10-03-2007 06:25 PM
33x12.5's fit? wessy YJ Wrangler Technical Forum 5 04-22-2007 09:24 PM
33x12.50 JeepPirate TJ Wrangler Technical Forum 3 11-15-2006 11:28 PM
33x12.5? Max1775 TJ Wrangler Technical Forum 3 03-28-2006 01:59 AM
