I have read the posts and still need advice on oil pressure gauge issue - JeepForum.com
post #1 of 19 Old 03-02-2013, 06:07 PM Thread Starter
rubinscube
1988 yj with 4.2
gauge pegs at 80 psi when I started vehicle.
I changed the only sensor I could find on the passenger side/ lower engine / 2 prongs with no success, and I am unable to find the short.
many posts have another sending unit by the distributor cap, but mine seems to not be one of them I guess.
any advice would by much appreciated as I am about to take a hammer to the dash and buy an aftermarket mechanical unit.
rubinscube is offline
post #2 of 19 Old 03-02-2013, 06:16 PM
gbeltran
The two prong sensor is something for the computer or the manifold heater, dont remember which, the oil gauge uses a 1 post sensor, it's pretty large compared to that two post deal, shaped like a bell. It's right below that one or just next to it, IIRC.
gbeltran is offline
post #3 of 19 Old 03-02-2013, 06:21 PM Thread Starter
rubinscube
great. I am getting a flashlight and going outside to check right now
post #4 of 19 Old 03-02-2013, 06:27 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Originally Posted by rubinscube View Post
1988 yj with 4.2
Here is what you need:
http://www.gbaparts.net/electrical/o...-53005218.html
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #5 of 19 Old 03-02-2013, 06:35 PM Thread Starter
rubinscube
I uploaded a pic of the sensor I replaced. I did not see another
post #6 of 19 Old 03-02-2013, 06:37 PM Thread Starter
rubinscube
Originally Posted by laybackman View Post
I think I am missing something. I just bought this "nutter-fide" jeep. maybe they went too far in removing parts?
post #7 of 19 Old 03-02-2013, 06:44 PM
gbeltran
I think so, well don't know if they went to far as opposed to removing the wrong part. No, you are not missing anything where your arrow is, where the other sensor is now there is supposed to be a T fitting that the computer sensor and the oil pressure sensor screw into. You need to find the wire that goes to the gauge that's dangling around somewhere in the mess of wires (a wiring diagram would help ) and replace the two prong thing you have with the proper sending unit, which is in the link that laybackman posted, and just connect the proper wire to it.
gbeltran is offline
post #8 of 19 Old 03-02-2013, 06:47 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
I think that is your knock sensor. look at the area just above your oil filter
post #9 of 19 Old 03-02-2013, 06:56 PM Thread Starter
rubinscube
ok. I found this thread with a picture that has a "T" you spoke of, & I do have an electric choke. if this is an example of what it should look like, I think you have solved it; and it looks like I need that darn "T" part.
http://www.jeepforum.com/forum/f57/h...-lost-1302883/
post #10 of 19 Old 03-02-2013, 07:01 PM
gbeltran
The knock sensor on the 4.2 is located on the intake, just in front of the carb.
gbeltran is offline
post #11 of 19 Old 03-02-2013, 07:09 PM Thread Starter
rubinscube
is this the wire? it was right next to the other plug and has only 1 spade connection.
post #12 of 19 Old 03-02-2013, 07:13 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Is it? Jeep had to do it differently didn't they Most older engines has them in the lower block. If they were too 'sensitive' you added more teflon tape to the threads so it would not 'hear' as well....
I stand corrected!
post #13 of 19 Old 03-02-2013, 07:16 PM Thread Starter
rubinscube
I stand corrected!
LOL the old timer at our jeep dealership here in Colorado said:
"jeeps were put together with what they had on hand at the time it was made".
post #14 of 19 Old 03-02-2013, 07:26 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
That is it1 read the link provded earlier Ir aow howw theb'plumbing is in tthe shape of a T to hook up both sending units
post #15 of 19 Old 03-02-2013, 07:29 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
post #6
oil , pressure , switch
