I have a massive oil leak, not sure of the source. - Page 2 - JeepForum.com
post #16 of 16 Old 03-30-2002, 09:46 AM
4wheeler4CJ
4wheeler4CJ's Avatar
I'm not sure about your exhaust, my setup was all modified, with dual exhaust headers and everything was custom from there out.
Aside from that, yes, you unbolt only the side of the motor (driver's I think) where the mount is in the way of getting the pan off (have to unbolt the mount from the side of the block), and just lift the motor enough to get the pan out. You can put a floor jack under the flat part of your bellhousing and jack from there, that works best, unless you have an engine hoist, LOL
4wheeler4CJ is offline
Massive Coolant Leak. Dunno for sure where from Hella TJ Wrangler Technical Forum 5 09-18-2009 09:36 AM
1987 yj Massive oil leak,, HELP!!!!!!! eche981 YJ Wrangler Technical Forum 4 07-05-2008 08:13 PM
Massive Oil Leak..Please Help DiabloYJ YJ Wrangler Technical Forum 6 08-25-2007 08:09 PM
massive oil leak alvalolo YJ Wrangler Technical Forum 2 10-27-2006 09:23 AM
Massive Oil Leak rjames1731 YJ Wrangler Technical Forum 7 06-26-2006 02:21 PM
