I hate rust - JeepForum.com
post #1 of 7 Old 03-31-2013, 09:06 PM Thread Starter
JohnnyZJ
I hate rust
Not only is it eating through my floorboards its making stuff stick together. Drivers rear wheel is rusted solid not even the sledge hammer is budging it. And of course the trackbars are seized solid. Those I think I will just cut off but the wheel is puzzling. It is an aluminum wheel. Any ideas before I oull the whole shaft?
I hate rust ugh.
07' JKUR rollin on 35s
JohnnyZJ is offline
post #2 of 7 Old 03-31-2013, 09:10 PM
flashy
As far as the aluminum rim is concerned....just beat on it from the back with a BFH. At least a 3LB sledge, anything smaller wont have enough omph to get it off. Then when you put it back on, put a lot of antisieze on the mating surface. Im from WI, ask me how I know. I thought I was going to have to cut the unit bearing off the rim on my wifes saab.
Time and budget build...lots of pics::::
94 YJ slightly modified
00 WJ stock
flashy is offline
post #3 of 7 Old 03-31-2013, 09:13 PM
flashy
BTW put a board between the rim and the hammer if you are worried about marring the rim. I have never done that and I have never damaged a rim. Knock on wood. Aluminum and steel dont corrode well together.
00 WJ stock
flashy is offline
post #4 of 7 Old 03-31-2013, 09:43 PM
gunshw301
Not real sure if its kosher....but I broke one free one time doing this.
Loosen all lugs on offending wheel, don't remove, just loosen a little. Then turn wheel back and forth. With any luck it will pop loose and then you can remove it. I might have also blocked it against a concrete wall, don't remember, but it was a pain. Keep at it, you will get it eventually.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #5 of 7 Old 03-31-2013, 10:40 PM Thread Starter
JohnnyZJ
Well its on the rear. Will try swnging from behind. Its on there pretty good thats for sure
JohnnyZJ is offline
post #6 of 7 Old 04-01-2013, 07:17 PM
flashy
Just beat the living tar out of it....it theraputic!
00 WJ stock
flashy is offline
post #7 of 7 Old 04-01-2013, 09:32 PM Thread Starter
JohnnyZJ
Heat + sledge = win. Trackbar was seized solid. Out came the sawzall. No more track bar .new exaust sounds sweet too, deeprumble instead of the falling off/rattling sound. Now onto fixing the cancer around the floorpan.if it turns out I will do a thread
JohnnyZJ is offline
