I Hate My Clutch! - JeepForum.com
post #1 of 24 Old 04-10-2013, 07:47 PM Thread Starter
ign_cas
I Hate My Clutch!
Ok guys. I have a 91 Wrangler (6cyl). First off let me start by saying that I am a college kid and this ride is my only mode of transportation. And with that said, I feel like I'm about to write an essay.
So, over spring break I dropped the tranny. Bought all new parts and replaced the clutch, pressure plate, slave/throwout bearing, and pilot bearing. I also had the flywheel resurfaced and filled up the tranny with Penzoil Syncromesh. Also installed a new clutch master cylinder (after going back to Autozone 3 times because they leaked).
After putting everything back together I bled the clutch 3 different ways.
1) Someone pumping pedal and holding while opening bleeder.
2) Putting a mighty vac to the bleeder and sucking all the air out.
3) Just opening the bleeder valve by itself (gravity).
(I could not find any leaks in the line)
After doing all this it worked fine. 1st was a little hard to get into gear and reverse would grind. Only about half the clutch pedal had pressure. Then I drove it more and realized my pedal was bottoming out before it hit the ground. Then the pressure would be less and less until I could only use 1/3 of the pedal. Then it got to the point where I couldn't shift it gear.
When driving home from school it got really bad. Usually I could turn my car off at a red light, put it into 1st, turn it back on then go when green. Now, I cant even do that because if I turn it off and put it into gear and turn it back on, it wants to shut off right away unless I give it gas.
I had to pull over and I was able to fix it temporarily. I was able to do this by opening the bleeder valve and little a bit of fluid come out. Then I would close it and the clutch would be back to normal (about half the pedal with pressure). But after a few miles it would happen again.
I'm getting really frustrated. I want to Any ideas guys? All the parts are new and I hope I don't have to drop the tranny again. Thanks guys.
ign_cas is offline
post #2 of 24 Old 04-10-2013, 08:10 PM
Xpress
Could be a loose fitting. I believe they are internal slave? Either that or it's typical AutoZone junk. I've had 3 of their POS slave cylinders fail on me. Luk might be your only option, and I would replace the slave and master at the same time.
All about that unibody life.
Xpress is offline
post #3 of 24 Old 04-10-2013, 08:15 PM Thread Starter
ign_cas
The fitting seemed to be fine. On the first master I got it leaked out the rod, so i could see the fluid behind the clutch pedal. And I know they're not the best , but they're also not the worst. I remember doing this to a Comanche I had and it all worked out find. I even used one of the masters from Autozone as well. And yea. I did replace the slave and master at the same time.
ign_cas is offline
post #4 of 24 Old 04-10-2013, 08:18 PM
Xpress
The AZ stuff is pretty notorious for being pretty crap, fails pretty easily. I'd consider investing into some higher quality stuff.
Xpress is offline
post #5 of 24 Old 04-10-2013, 08:31 PM Thread Starter
ign_cas
I bought that master cause I'm on a low budget and I can't really afford this Jeep anymore, so in trying to fix it up a little more to sell it. I'm not trying to spend a ton of money on it right now. What if the masters ok? Can there be another reason for this?
ign_cas is offline
post #6 of 24 Old 04-10-2013, 09:56 PM
bigbossd1030
I am saying master. They don't have to leak to not work. When the jeep is running. Have it in neutral and pump the clutch. Then try first gear. If it worked the mc is shot. Do this when the clutch starts acting up. Pump it about 6-10 times. Spend the 105 bucks on a decent mc, that's what they cost up here. I just get the napa brand and haven't had any issues. Or test to make sure it is the problem and sell it as is, tell them it's shot. I bought mine with a shot mc. I drove it like that for 6 months lol.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #7 of 24 Old 04-10-2013, 10:32 PM Thread Starter
ign_cas
I did that and I didn't do anything. My clutch started acting bad right now before I got home and I pumped it to see if it could get the pressure back and nothing happened. That's why I'm thinking its not the master cylinder. I'm going to try bleeding it again tomorrow morning.
ign_cas is offline
post #8 of 24 Old 04-11-2013, 06:47 AM
bigbossd1030
It's either that master or the slave based on the info we received.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #9 of 24 Old 04-11-2013, 08:14 AM
Siva283
It sounds like a faulty slave cylinder. Since you can bleed it by only letting out a little fluid that says the air is getting in the slave not the master.
Ask me how I know...
Siva283 is offline
post #10 of 24 Old 04-11-2013, 11:44 AM
zeus87gn
1987 YJ Wrangler
I'm guessing you still have air in the system
You have to bleed the system in a specific way or you won't get all the air out
1 - 'Bench bleed' the master cylinder first - since you already have it installed, brake the line fitting loose (but don't take it off) and have your helper depress the clutch pedal slowly - you will likely see tiny air bubbles come out through the threads - tighten the fitting before your helper lets up on the pedal - repeat as needed
2 - bleed at the slave - DON'T PUMP THE PEDAL - it will only churn up the fluid and make the fluid frothy, thus harder to get the trapped air out - brake the bleeder valve open first, then have your helper depress the pedal as if you were pressing it normally - close the valve and repeat as needed - keep a close eye on the fluid level in the master - you will probably only get 3 bleeds from 1 master filling
The possibilities of having bad parts right out of the box is a real problem
If bleeding it like I described above doesn't solve the problem, then I would agree with a bad component
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #11 of 24 Old 04-11-2013, 11:46 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
do you have fluid leaking from the slave? have you checked all the lines? check out this link. I made a power bleeder because i could never get my clutch bled. This worked like a charm.
http://www.jeepforum.com/forum/f12/p...l#post15008899
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
post #12 of 24 Old 04-11-2013, 12:26 PM
Nerfz
1987 YJ Wrangler
Its the slave I went through the same issues with the crap one there...
Get one from Quadrotec.com..
Nerfz is offline
post #13 of 24 Old 04-11-2013, 04:16 PM
ezk83
Slave set up I had the same issues with brand new stuff.
ezk83 is offline
post #14 of 24 Old 04-12-2013, 07:21 AM
whiskeywiz
i just bought a slave yesturday due to it leaking and thereby losing clutch once the reservior empties. Skimming over the slave instructions it says NOT to break the plastic bands off of the unit and it specifies a particular procedure for bleeding after install that will break in the unit properly, otherwise failure will occur. Did you do any of this or did you just slap it in and go?
whiskeywiz is offline
post #15 of 24 Old 04-12-2013, 07:31 AM
Siva283
Slap it in with the bands on. Pump up clutch with pedal when its in and go
Siva283 is offline
