I got a seat belt issue - JeepForum.com
post #1 of 4 Old 04-03-2010, 08:41 PM Thread Starter
MWguy101
Alright guys, as part of my jeep restoration project I took off my front seat belts. The driver side seat belt wond it self in way to much. So now I can not get it to release the seat belt so I can reinstall it. I am not sure what to do here. I have played it with is, put screw drivers in it, but nothing helps. Got any suggestions?
95 YJ, 4" RC lift, 33x12.50x15 Durtrac
MWguy101 is offline
post #2 of 4 Old 04-03-2010, 08:53 PM
FredBull
1993 XJ Cherokee
You have to make sure the seat belt is straight up and down before you can pull it out. place it in the area where it should be installed, in the same position it was before you took it out, then try to pull it out. You might have to play with it at different angles to get it to come out.
FredBull is offline
post #3 of 4 Old 04-03-2010, 09:05 PM Thread Starter
MWguy101
I tried that. It did not work.
MWguy101 is offline
post #4 of 4 Old 04-07-2010, 02:04 PM Thread Starter
MWguy101
I fixed my seat belt issue. I had to break a piece of plastic off the back part of the factory seat belt. Then use a flat heat to release the break. It still works and reinstalled. Not sure how safe it will be, so I might invest in new belts in the next couple of months.
MWguy101 is offline
'98 TJ Bolt Sizes: driver's seat and rear center seat belt ah77 TJ Wrangler Technical Forum 3 06-24-2009 06:18 PM
Installing Child Car Seat -- Locking Seat Belt? Skotty YJ Wrangler Technical Forum 6 01-06-2009 10:56 AM
Rear seat and accompanying seat belt bolt sizes? bjjfoshizzy TJ Wrangler Technical Forum 2 10-27-2008 06:08 PM
Seat Belt Swap issue YJ Rider YJ Wrangler Technical Forum 3 07-16-2008 06:34 AM
Stupid seat belt issue... ScottD06X TJ Wrangler Technical Forum 28 06-26-2007 08:27 PM
