I found an NP231 J transfer case for $125 - JeepForum.com
post #1 of 9 Old 09-18-2013, 03:44 PM Thread Starter
jeepguy85
1987 YJ Wrangler
I found an NP231 J transfer case local for $125. Should I pick it up to replace my NP207? Thoughts?
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
post #2 of 9 Old 09-18-2013, 04:12 PM
roadyrob
1987 YJ Wrangler
you need a transfer case with a 21 spline. they came with the puggy trans and in 4cyl jeeps, 6 cyl has a 23 spline.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #3 of 9 Old 09-18-2013, 04:14 PM Thread Starter
jeepguy85
1987 YJ Wrangler
I read you could swap the input shaft for a 21 spline if it is the 23 spline shaft. Is that not true?
post #4 of 9 Old 09-18-2013, 04:41 PM
Randonexplosion
Deplorable
Randonexplosion's Avatar
Yes you can. What year Jeep is it from? I have my old 21 spline shaft if you are interested.
Randonexplosion is offline
post #5 of 9 Old 09-18-2013, 05:39 PM Thread Starter
jeepguy85
1987 YJ Wrangler
I spoke to the guy and it is a 21 spline. Someone else is looking at it tonight. If he doesn't take it, it will be mine.
post #6 of 9 Old 10-23-2013, 03:35 PM Thread Starter
jeepguy85
1987 YJ Wrangler
I just found a 21 spline NP231j for $75! Now, does anyone know a good swap write up? From what I have read, there are only a couple of smaller items to address with the swap. Is that right?
post #7 of 9 Old 10-26-2013, 06:51 PM Thread Starter
jeepguy85
1987 YJ Wrangler
So the other TC I was looking at got bought. However, I found another listed at $75 so I drove up to look at it and ended up buying it for $60. It was an NP231 AMC, built in 88. I had to buy a speedo gear and gear housing because they were gone, but I am still in for $100. Now to finish the Ford 8.8, SYE and Woods DS!
post #8 of 9 Old 10-30-2013, 08:05 PM
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
The 4x4 shift linkage should need to lengthened 2" if I recall. It's a direct bolt in though.
Thomas
-1987 YJ
Tompatt is offline
post #9 of 9 Old 10-30-2013, 08:11 PM Thread Starter
jeepguy85
1987 YJ Wrangler
Thanks!
