I fixed the leak in my dash. Almost!!! - JeepForum.com
post #1 of 7 Old 05-12-2002, 02:34 PM Thread Starter
battlestar
I had water leaking in from under my dash. I bought a new piece of cowl rubber from quadratec becuase I suspected that was the problem. I disconnected the rollbar and flipped my windshield forward and I was partly right. Apparently the holes from the softop hardware, which was no longer in place, was letting water into the windshield frame. There was a hole cut out in the gasket and the water would pool up on top of the dash right under the windshield frame. There was a lot of rust. I cleaned it up, put in the new gasket and was all happy becuase now I could buy a radio. Well, it turns out that when I folded the frame down, one of the hinges was siezed and instead of folding at the hinge, the windshield frame and hinge bent. Now my jeep is all screwed up. I have to find new hinges and a windshield frame. I kind of needed them anyway, but I'm still pissed.
I just thought I'd share this becuase I see alot of posts about leaks behind the dash and I sure alot of them are for a similar reason.
My Ride: 1990 YJ, 4.2, 5 speed, msd ignition, TFI Cap, 4" skyjacker lift, 1/2" shackles, nutter bypass, bestop seats, herculined floor, Flowmaster, Oversized cat, Xterrains on Rock Crawlers
battlestar is offline
post #2 of 7 Old 05-13-2002, 07:46 AM
RCHavok797
RCHavok797's Avatar
I need to replace mine too. Whenever it rains hard I get water seeping in from behind my dash. Luckily it hasn't ruined anything yet. How much was the cowl? I'm just scared when I go to fold the windshield down that there will be tons of rust as you mentioned.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #3 of 7 Old 05-13-2002, 08:56 AM Thread Starter
battlestar
The cowl rubber was only about $27 from quadratec. It was good quality and fit well. Make sure you put some WD-40 or something on the hinges for a couple of days before you do the job, or you might bend the hinges and frame like I did.
post #4 of 7 Old 05-13-2002, 09:54 AM
Prime Lord
Prime Lord's Avatar
Location: Chesapeake, VA (My office is just hell w/ florescent lighting)
What part is this exactly? I've got the same leak.
I've got some rust under my windsheld too...
<img src="http://community.webshots.com/storage/1/v3/5/77/44/37557744MTfsxI_ph.jpg" alt="" />
You can see it off to the drivers side...
I think the majority of my water is coming from the vent on the hood in front of the windsheild though....if I cover it up in the rain, I don't get anywhere near as much water inside.
~Jay
, 4.0, 5-speed. 1" Daystar Body Lift, 31x10.50 Goodyear MT/R's, CJ Style (87-91) Roll Bar, ARB Safari Snorkel, K&N Panel Filter, Dynomax SuperTurbo Catback. Still hunting for TJ Sahara flares!!!
, Maximum Motorsports: Rear LCA's, 4-point K-Member brace, & Std Length Subframe Connectors, FRPP 'C' Springs, Mac Pro-Chamber, Chrome BBK equal length shorties, B&M Ripper w/ leather cobra knob.
Prime Lord is offline
post #5 of 7 Old 05-13-2002, 11:36 AM Thread Starter
battlestar
I can't see the picture you posted, but the piece I bought(cowl rubber) fit between the windshield frame and the body/firewall. If you flip your windshield forward, the cowl rubber is attached to the underside of the windshield frame. By replacing the cowl rubber I would have solved only part of the problem. The windshield frame would still be filling up with water. I was going to put silicone in the holes on top of the frame, but now I need a new frame.
I just got back from the Jeep dealer. Ridiculous!
Windshield frame: $809
Hinges: $128 each
Hardware: $32
Quadratec sells a windshield frame for $140, Its just that I wonder what the quality is.
post #6 of 7 Old 05-13-2002, 02:19 PM
geepYJ95
OUCH!!!!!!! that really puts a hole in the wallet. I think I'll wait to put the windshield down....maybe until this summer when I get new speakers in the dash. Probably should replace the seal while I'm at it too..huh??
Green Jeep Club Member #14
'95 YJ Sahara Edition, green w/ tan hard and soft tops, Flowmaster 40 series, New cat, 2 10"eclipse subs, pioneer cd deck, and Xtant A series 6001 amp.
geepYJ95 is offline
post #7 of 7 Old 05-14-2002, 06:34 AM Thread Starter
battlestar
I found a windshield frame with hinges and glass at a junkyard for $200. I'm going to check it out today. If it is half way decent, I'm going to get it.
Cowl Leak Fixed - thanks all! Pewter05 TJ Wrangler Technical Forum 0 12-02-2009 05:33 PM
Heater core leak fixed drew2000 YJ Wrangler Technical Forum 2 05-25-2009 04:09 PM
I think my leak is fixed gdw0717 JK Wrangler Technical Forum 3 11-23-2008 08:05 AM
