I finally ordered my Old Man Emu kit! - Page 7 - JeepForum.com
post #91 of 92 Old 08-27-2011, 09:13 AM
hrt4me
Originally Posted by moonshinefuel View Post
Congrats! You won't need the cv/sye kit for the 2.5 lift. I even put a 5/8ths shackle lift with the 2.5 suspension lift. Sure it would be good to have, but you don't need it. NO worries! The rear leafs are shimmed, so it will angle up some, use the t-case drop, and if you really need to, the motor mount lift, but I don't think that will be necessary. One reason why some people experience vibes is because the driveshaft needle bearings do tend to wear a certain way when driven at that angle for a long period of time, and in worse case you can just replace a u joint or motor mount lift. But your angles should be fine. Installing a t-case lowering kit and the shims will get you right where you want to be. No Worries! It is an excellent riding suspension, better than stock ride, excellent articulation, and it will boost your rig up min. 2.5 inches higher than stock. (my driveshaft has 274,000 miles on it original, and I did not experience any vibes at all after install. It is perfect. (just when time and money allows, later on down the road, go ahead and get the sye kit if you want)
Originally Posted by ar4130 View Post
Check out the part #'s on your springs and see which ones they sent you.
Here is the ARB application guide for their YJ products, including their Old Man Emu Springs.
http://www.arbusa.com/uploads/PDF/ac...WranglerYJ.pdf
good to know, thanks!
hrt4me is offline
post #92 of 92 Old 08-27-2011, 11:00 AM
giggityjeeper
Originally Posted by jchav74 View Post
What is the difference of a front or rear spring? Are they interchangable? I have a hard top and tire carrier, so figured heavy duty might be better in the back.
no difference, I have a spare set of 14 out back of my house, I am now SOA and the 14 wont hold that, I changed for the 36R, 5 pack and run those front and rears and wuold recommend to ANYONE do the same, I ran 14 on the front for years and the flex was MAD, I never nor do I now have a winch, but soon as I wnet SOA the 14 started to sag... so I ordered 2 new 36R for the front and problem solved....
just get the 36 and be done, the ride is STILL uber nice
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
FINALLY ORDERED MY SKYJACKER but.................. wegotj TJ Wrangler Technical Forum 13 06-08-2007 12:40 PM
Well I finally ordered my 4dr Rubicon Mortikhi JK Wrangler Technical Forum 5 02-10-2007 08:49 AM
ordered my lift finally! Mudder6699 TJ Wrangler Technical Forum 6 04-18-2006 07:12 PM
Finally ordered it blevinsbulldog1 YJ Wrangler Technical Forum 2 02-21-2006 06:50 AM
finally ordered me a bumper incubus2012 TJ Wrangler Technical Forum 6 03-24-2005 09:18 PM
