I don't have a Cat converter and my 02 is disconnected - JeepForum.com
post #1 of 6 Old 08-18-2011, 07:16 AM Thread Starter
bogleparsons
OK well I've been digging around inside my toy and realized the following to be a fact.
I have no catalytic converter - been removed at some point
I have no mass air flow sensor - this i think is normal??
My 02 sensor wires are just cut off- someone thought it was not necessary
But my jeep runs great, and i think i get around normal gas mileage, should i be concerned?
bogleparsons is offline
post #2 of 6 Old 08-18-2011, 08:52 AM
R3V413
Do you have emissions testing in the state where you reside? If so has it passed the tests? If it has then I wouldnt worry about it. What would you consider "normal" gas mileage?
JEEP=Just Empty Every Pocket
"Politics is war without bloodshed while war is politics with bloodshed."-Mao Zedong
"For Those Who Fought For It, Freedom Has A Flavor The Protected Will Never Know"-Unknown
00 TJ on 31x10.5x15's- DD
89 YJ-Under the Knife
R3V413 is offline
post #3 of 6 Old 08-18-2011, 09:03 AM
Que89YJ
You need the O2 sensor to regulate the fuel output. Without it you are not going into closed loop and it will run but not efficently. I bet you are only seeing 14 MPG max. There isnt a Mass sensor on a jeep are you talking about the MAT Manifold air temp?
Que89YJ is online now
post #4 of 6 Old 08-18-2011, 09:09 AM Thread Starter
bogleparsons
No we don't have emissions for vehicles older than 1995.
I get about 10-14 mpg yes I was under the impression it was to be expected.
post #5 of 6 Old 08-18-2011, 09:25 AM
Que89YJ
No, you should see at least 17 on the freeway. you should definitely fix that. I had donating money to the oil companies. They already pick our pockets bad enough.
post #6 of 6 Old 08-18-2011, 09:42 AM Thread Starter
bogleparsons
Agreed , I'm a tight wad and hate gas prices.
I don't do any hi-way or freeway driving really... I live 5 miles from work and that's on the outskirts of the city.
I'm going to look into an 02 sensor, why not it should be sorta cheap.
Catalytic converter/muffler rattle, replaced converter..still rattling eastwood1972 TJ Wrangler Technical Forum 8 05-20-2010 09:46 AM
im disconnected now ??? 2005X TJ Wrangler Technical Forum 34 01-16-2006 05:04 PM
going disconnected? coorsmgood TJ Wrangler Technical Forum 24 11-07-2005 08:04 PM
disconnected 97sahara TJ Wrangler Technical Forum 2 06-15-2003 05:01 PM
disconnected or no? cptyarderho TJ Wrangler Technical Forum 4 06-25-2002 09:39 AM
