I discovered this afternoon that my '91 YJ came with cruise control... (help) - JeepForum.com
post #1 of 9 Old 08-16-2011, 09:44 PM Thread Starter
hrt4me
(*not really*)
My '91 YJ has mostly factory OEM parts, which is surprising for a 20-year-old Jeep with only 55,000 miles (I am the third owner and just got it this past May). Well, I was driving on the interstate this afternoon when I shockingly discovered that my gas pedal sticks! There is noticeable resistance after I press down the throttle approximately one third to halfway toward the floor / firewall, and I have to press relatively harder to get past this point of resistance. Once past this point of resistance, however, the gas pedal sticks and does not come back unless I tap / kick the pedal. I've put 1060 miles on the Jeep during these past 3 months and have never before experienced nor noticed this issue.
Someone checked my throttle cable and assessed that it was relatively new and had been replaced recently, so other than that, I really have no idea how to diagnose this, and thus, would appreciate any recommendations on what to check next to remedy this problem...?
Thanks in advance!
hrt4me is offline
post #2 of 9 Old 08-16-2011, 10:51 PM
Xpress
Check your throttle body to make sure there is no gunk inside of it that is making it stick. Then I would remove your throttle cable and lubricate it.
All about that unibody life.
Xpress is offline
post #3 of 9 Old 08-17-2011, 06:37 PM Thread Starter
hrt4me
Thanks for the reply and advice; with what should I lubricate the throttle cable?
hrt4me is offline
post #4 of 9 Old 08-17-2011, 06:51 PM
TheNewbie
Yep. Check the butterfly valve at the throttle body. If you unhook the cable does it move smoothly? The spring will make it kind of hard to move, but it should not stick at any point. And you should be able to easilly move it with one hand. If you still feel it sticking then you know that it's in the TB. I would hit it with some TB or carb cleaner. I would even take the spring off and get a wire brush into every little nook that you can.
Not sure waht to lube the cable with as I've never done that. But I'd clean the heck out of the TB either way.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #5 of 9 Old 08-17-2011, 06:54 PM
Reddy89
My 89 manual has cruise control... or at least the knob/lever, I "turned it on" but nothing happened.
I have some PB Blaster Lubricant I use, you could use WD40 or a bit of lubricant grease/oil.
Reddy89 is offline
post #6 of 9 Old 08-17-2011, 07:02 PM
Xpress
I lubricate my motorcycle cables with DOT3 brake fluid all the time, since I have a few bottles of it lying around, but I think the best would be to use 3 in 1 oil.
Xpress is offline
post #7 of 9 Old 08-18-2011, 01:58 AM
kphimself
You should only use graphite powder to lubricate a cable otherwise dust will stick to it and cause it to bind and stick. They sell it all auto parts stores and hardware stores.
kphimself is offline
post #8 of 9 Old 08-18-2011, 03:41 AM
oldtime_ironman
It's not hard to lube a cable. I like to use the white lith grease that comes in a spray can. I just pull one end out far as it will go. douse it with the spray. Then work it back-n-forth a few times. Then do the other end the same way. The weave in the cable wicks it up inside the cover.
Another good one to use is "3-in-1" brand sewing machine oil. Dunno if they make it anymore tho - check the hardware.
oldtime_ironman is offline
post #9 of 9 Old 08-18-2011, 05:56 AM
Andywear
put some beer in it.
That always loosens up the o'lady
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
Cruise Control tubing broke atleast I think it's cruise control Lefty TJ Wrangler Technical Forum 3 11-23-2010 06:20 PM
09 Cruise control firesprk JK Wrangler Technical Forum 13 02-01-2010 07:56 AM
Cruise Control Braggjr TJ Wrangler Technical Forum 9 04-03-2008 08:12 AM
Cruise Control IdahoStroker TJ Wrangler Technical Forum 17 12-07-2003 07:32 AM
Cruise Control and A/C ColumbusJeepGuy TJ Wrangler Technical Forum 1 11-15-2003 02:17 PM
