i can't get my dana 30 hub out to replace the seal - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > i can't get my dana 30 hub out to replace the seal
REPLACEMENT SOFT TOP SALE AT BASELINE 4x4 OUTFITTERS - 88-2001 - 2004 Jeep Grand Cherokee Power Window Regulator wit1990 - 1998 Jeep Cherokee Front Wheel Bearing & Hub As
Unread 01-11-2009, 08:34 PM   #1
yj_beater51
my axle has been leaking and i need to get in there and replace the seal. I'm able to get the brakes off then the center nut off. I'm stuck now. can anyone help me out with tips or tricks to get the 3 12 point head bolts out so i can take the shaft out
yj_beater51 is offline   Reply With Quote
Unread 01-11-2009, 08:47 PM   #2
pman
Eat More Possum
pman's Avatar
Soak those bolts overnight with PB Blaster. Then, put your rachet to each bolt and pop the rachet handle with a dead blow hammer. That should loosen them up so you can remove them. BTW, you have twelve point sockets, correct? Actually a box end wrench (12 pt) would be more ideal to prevent stripping the head of the bolt.
88 Wrangler Laredo 4.2L 32" BFG MT's 3 1/4" Lift
Aussie Locker (Front)
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
http://www.jeepforum.com/forum/f8/cj...-lulu-1350563/
pman is offline   Reply With Quote
Unread 01-11-2009, 08:51 PM   #3
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Read this:
http://www.jeepforum.com/forum/f12/axle-ujoint-replacement-yj-dana-30-a-360209/
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Unread 01-11-2009, 08:52 PM   #4
yj_beater51
would you by any chance know what size that would be? i was using a 13mm
Unread 01-11-2009, 08:54 PM   #5
rustywrangler
It is a 13 MM. You need a 13mm deep socket
Unread 01-11-2009, 08:58 PM   #6
yj_beater51
thank you so much for the help
