I can't remove Ignition Lock Cylinder Can somebody help - JeepForum.com
post #1 of 4 Old 04-01-2010, 01:46 PM Thread Starter
gary1
gary1's Avatar
I'm trying to replace my wiper switch and having all kind of trouble getting things apart. Chilton and Haynes aren't helping much. I can't get the shroud off the steering column. My ignition cylinder seems to be different than the manual shows. There is no screw inside holding it in, but I still can't get it to slide out. I thought I'd made this repair once, but I think now I just replaced the turn signal switch which is easy to get out. Does the wiper switch take some special tool to get it out.?
To acquire knowledge, one must study; but to acquire wisdom, one must observe.
gary1 is offline
post #2 of 4 Old 04-01-2010, 02:00 PM
Honkeymudderfo
1987 YJ Wrangler
On some lock cylinders you must insert the key, turn the lock to a certain position usually ON, then do you see a little pin or piece of metal that you can push down thet lets it come out when pulled. Finesse is the key here. Do you really have to remove the lock to get to the wiper switch ?? Never experienced that personally, however I dont know what you are working on..................
/l ,[____],
l---L -0lllllll0-
()_) ()_)--O-)_)
Honkeymudderfo is offline
post #3 of 4 Old 04-01-2010, 03:57 PM
Ingle47
Pictures will help but Mines like Honkeymudderfo said
Good luck
'05 Black WK Limited 4.7 /2" Daystar Poly/ rooftop tent/ cobra 29 ltb classic/ 265-75-17 Dynapro MTs/ Procomp 7" driving lights/ Saguaro switch panel/ 1.5" ws/ SuperChip/
'99 Blue WJ 4.7 / Stock
'89 YJ 4.2 /SOA/ 35-12.50-15 Tsl/ Cobra 29 LTB Classic/ XRC8/ Tube Fenders/ Side Armor/ 8.8" rear/ 1.25 WS/
Ingle47 is offline
post #4 of 4 Old 04-01-2010, 04:48 PM
remmons
X2.
I wish that I had taken pics of my column. I had to start from scratch to build my column.
At the end of the lock cylinder, there is a little tab that engages with the notch. If you locate the end of the lock cylinder, you will locate this notch. Use a small scew driver to push down on this tag. The lock cylinder will slide right out whe nyou pull on it.
Good luck!
Robert.
remmons is offline
92 YJ can't remove ignition cylinder lock WhiteYJLA YJ Wrangler Technical Forum 8 02-08-2010 10:03 PM
Ignition cylinder busted out - How to remove? Devaclis YJ Wrangler Technical Forum 1 01-03-2007 08:40 PM
Ignition lock cylinder 72JEEPCJ5 YJ Wrangler Technical Forum 1 11-11-2006 01:42 PM
Ignition key lock cylinder ... $50???!!! LOCKED UP YJ Wrangler Technical Forum 8 05-11-2006 05:45 AM
Ignition lock cylinder bad?? todnshay YJ Wrangler Technical Forum 2 04-17-2004 11:22 AM
