I call her puddles...a timeline of events - Page 3 - JeepForum.com
post #31 of 36 Old 02-08-2013, 07:21 AM
Que89YJ
Hghgrad if you are ever in a pinch and need some help let me know. I am Downriver in Trenton. Not too far at all. I am going to start my build thread here in a few weeks. I just went down to Columbus and picked up a 4WD tub kit for $1500 for my Driveway Queen to start it going again. Fingers cross the waether will break and I can get going on it. No heat in the garage and I am turning a wrench in the cold garage. Those days are Long Gone!
Que89YJ is offline
post #32 of 36 Old 02-08-2013, 12:40 PM Thread Starter
Hghgrad
The plan is to toss an 8.8 in and some shafts in the d30, then buy some tires.
It barely clears the garage door now, so I'm going to have to grab a top of some sorts for the summer time to leave it outside. I don't care that it gets wet, I just don't want to sit down on a wet seat
I'm still feeling pretty good about the money I've spent putting this together. The latest expense was the aw4 swap stuff...which was cheap anyways.
Picked up the aw4 for $100
Already had a good flex plate from the old motor out of my Cherokee
$3 for the wiring harness connectors at the junkyard
Really only need some hoses and some warm weather to finish this up.
I'm with you Que, I won't be doing much of anything until it warms up a little. My days of cold garage wrenching are over, unless one of the DD's requires my attention.
1994 Wrangler...4.0 AW4 swapped, sye'd, 5.5" lift and 33's
Hghgrad is offline
post #33 of 36 Old 02-08-2013, 02:19 PM Thread Starter
Hghgrad
Here's some random pictures I took during the swap.
Re drilled to clock the case.
Tc shifter
Shifter is really close to the factory position. Just used 2 mounts from the tc to support the shifter bracket. It's pretty solid.
Hghgrad is offline
post #34 of 36 Old 02-11-2013, 04:15 PM Thread Starter
Hghgrad
Wiring is done, shifter installed, trans cooler installed.
I've gotta tighten some hose clamps and put fluids in the transfer case and trans. Might get around to buttoning it all up tomorrow. Need to clean up everything behind it so I can try to see if it will move under its own power.
Hghgrad is offline
post #35 of 36 Old 02-25-2013, 11:04 AM Thread Starter
Hghgrad
The aw4 swap is a compete success. Drove it around the block a few times and it was great. One small leak from a hose clamp, but tightening it up solved that problem. Leaving the country in a few weeks, and I'll be putting insurance back on and driving it after I get back. I trust it much more now with all the noises gone from the transmission area. Throw out and pilot bearings were both trashed, along with the clutch. Couldn't have rebuilt the ax15 and put all those new parts on for anywhere near what I spent on the aw4 swap.
Probably let my wife drive my Audi to save some wear and tear on her explorer.
With the new transmission and re sealing the transfer case...it's leak free for now. I'm sure it'll spring a leak somewhere else in the next few weeks to continue its legacy
Grand total.
$100 aw4
$13 for the console and shifter
$3 for the wiring and tcu
$60 in fluids and hoses
Round it to $200 for anything I forgot.
Sold the ax15 and external slave for $150
So...$50 total
Hghgrad is offline
post #36 of 36 Old 06-23-2013, 09:27 PM Thread Starter
Hghgrad
Ordered and installed some rocker guards...
Then I sold it about a week ago...
Wasn't driving it because of the unpredictable weather. When it was nice, I drove my audi because it has air conditioning. Putting a down payment on a new truck Tuesday. Something a bit more practical for my lifestyle right now.
I'll likely buy another wrangler in the next few years. Probably a tj though.
Hghgrad is offline
Puddles In My Jeep Prunetuck4X4 TJ Wrangler Technical Forum 12 02-25-2011 12:29 AM
jeep does not like puddles??? rogernes TJ Wrangler Technical Forum 7 02-10-2009 03:55 PM
So I went through some big puddles... 04WranglerX TJ Wrangler Technical Forum 4 11-04-2007 12:26 PM
Order Timeline? swagginman JK Wrangler Technical Forum 3 03-09-2007 08:11 PM
Bikini Top Puddles... Stiffler YJ Wrangler Technical Forum 22 05-20-2004 09:50 PM
