I call it the Basket Case. - Page 6 - JeepForum.com
post #76 of 272 Old 07-06-2010, 01:23 PM
A4T1Rat
What model trans is that? I have the same trans I am putting in my jeep swap. is it the electronic controled trans?
Injection is nice but Ide rather be Blown
A4T1Rat is offline
post #77 of 272 Old 07-06-2010, 04:02 PM Thread Starter
remmons
The transmission in question is an AW4 4-sp automatic. I also kept the NP242 selec-trac transfer case from the '88 Cherokee XJ.
Robert.
remmons is offline
post #78 of 272 Old 07-28-2010, 11:04 AM Thread Starter
remmons
I don't have much to report this week as that I have been struggling with free time this summer. When I do get time it is usually hotter than heck.
I managed to track down some wires that were needed, but found out that they were broken. I had to remove the transfer case shifter bracket in order to access the grommet where the solenoid wires entered the transmission case.
Here are the broken wires of the upper harness assy.
I had to splice these wires together using solder and heat shrink tubing. I ran another bigger tubing to cover the splices, then I ran the split loom to further protect it.
I still have to attach the harness assy. to prevent them from shifting around when in motion or laden down with mud. Then I will be onto cross referencing the wire codes to make the '88 harness compatable with the '93 harness.
The UPS man dropped off my package yesterday of front turn signal housings and one headlight bezel. I should be seeing the other bezel later this week, hopefully.
Robert.
remmons is offline
post #79 of 272 Old 08-20-2010, 12:06 PM Thread Starter
remmons
I have had some time to work on my Jeep last weekend. I picked up a pair of bucket seats from a yard sale, asking price was $100.00 for the pair. I went back at 2:00 p.m. and bought them for $60.00. It was the Score of the day!
Here is the passenger seat with the fabbed feet. I have the feeling that these did not work out for his project very well. (1974 Camaro).
I cut and ground off the feet and drilled out the mounting holes a little larger. Fortunately, the track width was close enough to work with!
I now have the drivers seat installed. I can release the seat and push it forward with plenty of room to allow a back seat passenger, even for me!
Here is the passenger seat is released forward, still plenty of room for access to the back seat.
Robert.
remmons is offline
post #80 of 272 Old 08-20-2010, 12:11 PM Thread Starter
remmons
Both seats are mounted in place. They both look like that they belong there.
Both seats can fully recline to their maximum position. They just barely hit the rear wheel wells.
Unfortunately, I do not know what make the seats are. I was fortunate to find a set of decent seats at a good price. Once I find out wha tmake they are, I will submit an entry into the sticky for seats.
With any hope, I will be working on integrating the TCU into the engine harness. Once that is done, all I have left to get the Jeep running will be the little stuff.
Robert.
remmons is offline
post #81 of 272 Old 08-21-2010, 06:23 AM
monkeyhouse
Attachment 142684
Attachment 142685
Hey, how did you get the seats out of my Cavalier?? Same color and everything, lol.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #82 of 272 Old 08-23-2010, 08:37 AM Thread Starter
remmons
I must've been sleep walking again.
Thank you for identifying the seats for me. They are a nice set of seats.
Robert.
remmons is offline
post #83 of 272 Old 08-23-2010, 03:48 PM
monkeyhouse
Gotta agree with ya there, they are nice seats, now I know what to look for, that is soo cool! Yeah, those are the exact seats I had in my 04 Cavalier 4 door.
post #84 of 272 Old 08-24-2010, 06:27 PM
TNGatorBrad
1985 CJ8
Great progress... I can't wait to see the final product.
TNGatorBrad is offline
post #85 of 272 Old 08-25-2010, 07:20 AM Thread Starter
remmons
I can't wait either. My main goal is to just get it to run, then I will get into performing a lift and other goodies for it.
I spent some time on it last night (pics coming soon), I figured where I wanted to mount the TCU (Transmission Control Unit), I roughly routed the wires where they needed to be. My next step is to integrate all the wiring of the TCU, Gear Slelector/NSS and the solenoid harness into the YJ/XJ engine harness. When this project is complete, I will have a wiring diagram for future use made up, not only for others here but also for my own reference, just in case something happens.
Robert.
remmons is offline
post #86 of 272 Old 08-27-2010, 12:57 PM Thread Starter
remmons
I managed to get some wiring done this past week. It seemed daunting at first, until I segregated the components and wires.
This week, I installed the TCU for the AW4 under the dash. There isn't much room to put one of these things, so it has been placed here for the meantime. Eventually, I will relocate it to where the Jeep PCM use to sit.
The TCM wires are identified and labeled as to where they go.
The connectrors and wires have been identified and ran accordingly. They belong to the Gear Selector/NSS switch and the AW4 Solenoid packs.
With any luck, this phase will be tidied and taped up by the end of the weekend. I should be able to start on the cooling system by then.
Robert.
remmons is offline
post #87 of 272 Old 08-28-2010, 07:19 PM
Shamrock84
holy sh*t thats a lot of wiring man, im glad this is ur project and not mine lol ill stick with the mechanical side cheers on the progress
Shamrock84 is offline
post #88 of 272 Old 08-28-2010, 07:21 PM
Shamrock84
haha ur pass side front fender is also same color and striping as my YJ sahara lol havent seen to many of the almost OD green. U planning on painting this thing later?
post #89 of 272 Old 08-30-2010, 10:22 AM Thread Starter
remmons
Yeah, I knew what I was getting myself into when I started, er inherited this project. Wait until later when I post the "after" pics. You wouldn't recognize that it was the same Jeep.
Yeah, I plan on at least painting the fender and the hood to match the rest of the Jeep. I haven't decided on a new color as of yet.
Robert.
remmons is offline
post #90 of 272 Old 08-30-2010, 03:31 PM Thread Starter
remmons
I made a huge dent in my wiring over the last weekend. I finally feel like that I had made some accomplishments!
Remember that huge mess of wires? Here is a reminder pic of it.
I had initially mounted the TCM under the dash at the steering column, but decided that the original PCM mount behind the glovebox was a better place to put it.
My wire splicing included crimping and soldering, then heat shrink wrapped.
After I determined where they needed to go, I straightened the wires and taped them at about six inch (or closer) intervals.
After I decided what wires needed to go where, I made the first full wrap with electrical tape.
Robert.
remmons is offline
yj with a mail basket yjcrawlr YJ Wrangler Technical Forum 12 07-25-2009 09:21 PM
ever seen a hood basket Rob95YJ YJ Wrangler Technical Forum 6 07-11-2009 10:52 AM
Cargo Basket help mountaineerjp TJ Wrangler Technical Forum 3 07-12-2007 11:36 PM
Basket for slant bar howellru YJ Wrangler Technical Forum 6 12-09-2006 09:12 PM
basket on hard top? chrisvr6 TJ Wrangler Technical Forum 1 07-19-2005 10:15 AM
