I call it the Basket Case. - JeepForum.com
post #1 of 272 Old 03-11-2010, 01:30 PM Thread Starter
remmons
I have had several inquiries regarding my YJ project. So I decided to start my own thread regarding the vehicles, parts and progress.
It all started out with the purchase of a 1988 YJ Laredo for three bills, and a 1988 XJ for one bill. The YJ was missing the tranny, transfer case, drive shafts, interior pieces like the front seats, and most of the dash was missing also.
It did have a MPI conversion started, but I am willing to bet that the PO had given up on this daunting task.
At this point, I can virtually do what ever I want to this thing. I elected to keep the motor that was dropped in, and use the Cherokee as a parts donor.
BASKET CASE YJ 001.jpg   BASKET CASE YJ 006.jpg   BASKET CASE YJ 011.jpg   BASKET CASE YJ 027.jpg   BASKET CASE YJ 030.jpg
Robert.
Last edited by remmons; 03-11-2010 at 01:42 PM. Reason: Picture links did not work the first time.
remmons is offline
post #2 of 272 Old 03-11-2010, 01:35 PM
timoteo1234
Pictures arent working for me. But sounds like a cool project. keep updating.
timoteo1234 is offline
post #3 of 272 Old 03-11-2010, 01:38 PM Thread Starter
remmons
The '88 XJ is a parts vehicle for the Wrangler.
It has no title, and it was not in running condition. The parts were strewn through out the interior. It appears that the PO had taken the top end off the motor to see why it did not turn over. I had discovered, during the tear down process, that the flex plate was broken.
I had recently purchased a new flex plate in order to begin the resurection.
I also noticed that the fuel tank wires were damaged.
I am willing to bet that a PO had misdiagnosed his engine troubles and dumped the Jeep with little knowledge as to what was really wrong. On this Jeep, the Crankshaft Sensor is the ring on the flex plate. So getting no timing AND no fuel was probably very frustrating for him.
Now, onto the project. I will keep this progress posted as time permits.
Robert.
remmons is offline
post #4 of 272 Old 03-11-2010, 01:39 PM Thread Starter
remmons
Very interesting. I just had them working a few minutes ago. I will work on this.
Robert.
remmons is offline
post #5 of 272 Old 03-11-2010, 01:41 PM
timoteo1234
nice, there they are. thanks.
post #6 of 272 Old 03-11-2010, 01:43 PM Thread Starter
remmons
No problem.
Robert.
remmons is offline
post #7 of 272 Old 03-11-2010, 06:29 PM
green89yj
sweet. thanks for the link and good luck. I am slowly assembling parts trying to get mine all back together. How complete is the wiring harness and engine on the cherokee? Could you tell me what the bundle coming out of the harness near the firewall side of the valve cover and I think going through the firewall is for? There are two bundles coming out there, the smaller one has a hose in it which I think is for the wiper motor and sprayer but the bigger bundle was completely cut and I don't know where it goes.
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline
post #8 of 272 Old 03-12-2010, 09:12 AM Thread Starter
remmons
I will have all the wiring figured out by this weekend.
There were three sets that passed through the firewall, plus the firewall connector. One of the sets was for the tail section including tail/stop lights, rear wiper and defrost, dome lights and the fuel pump. It also had the E-brake wire and the seat belt reminder wire set. I should have taken pics of the tear down process, but I was more worried to get that XJ out of my wifes parking spot.
I took virtually every part of the wiring harness, short of a couple feet of dome light wire. I did notice that the engine in the YJ had some upgrades performed before I bought it. It has been upgraded with the 4.0L head, intake and exhaust, and the engine compartment wire harness, so I will have to perform some cross referencing on this as well.
I managed to spend about an hour and a half on the tranny/transfer case install last night. This is where I am at thus far. (The transfer case pic did not turn out right).
I got the tranny bolts tightened to spec. I also got the transfer case installed and tightened to spec as well. While I was under there, I checked to see if my drive shaft that I bought from winners97tj would fit. It was a perfect fit. I will be replacing the U-joints before I install it.
I also managed to get the left motor mount installed last night.
It was missing when I bought the Jeep. I had to wrangle the motor around with a floor jack, and a chain hoist suspended from the garage rafters in order to get the mount holes to line up.
I was satisfied to this point with the install. So for now, the easy part is over with.
Robert.
remmons is offline
post #9 of 272 Old 03-15-2010, 03:52 PM Thread Starter
remmons
I managed to get in a full day over the weekend to work on the basket case. This is what I have thus far.
I discovered that the tranny mount would not line up with the YJ skid plate, so I drilled some holes to accept the mount.
So far, so good. I did have to take a BFH to the part of the skid plate where the NP242 hung down at for vlearance.
The easy pert is over. Now onto the linkages.
Robert.
remmons is offline
post #10 of 272 Old 03-15-2010, 03:58 PM Thread Starter
remmons
I placed the transmission shifter assembly into the stock 5 speed hole and determined that it was in an adequate place. I then determined the best place to drill out a firewall pass through for the cable.
This is my initial placement before setting the shifter assy. to the right side of the hole.
Here, it is passing through the firewall on the engine side. It is looking good for clearance from moving parts and exhaust at this point.
Robert.
remmons is offline
post #11 of 272 Old 03-15-2010, 04:06 PM Thread Starter
remmons
I reused the original transfer case shifter linkage bracket for the YJ. I had to bend the tabs to conform to the body contours, but it worked out great after it was done.
Here the linkage is all together. I did have to bend the mode rod into a zee shape by 2-1/4" in order to compensate for the offset placement of the transfer case shifter.
The end result of the shifters mounted. I only had to trim out about an inch of metal around where the transfer case shifter bucket recesses into the tranny hump.
The shifters work with no problem. I can get it into every gear with little trouble.
Robert.
remmons is offline
post #12 of 272 Old 03-15-2010, 04:09 PM Thread Starter
remmons
I am now moving onto the wiring of the basket case. I will have more tomorrow.
Robert.
remmons is offline
post #13 of 272 Old 03-15-2010, 05:03 PM
Fernando
Fernando's Avatar
1987 YJ Wrangler
Nice Project! Keep us posted!
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #14 of 272 Old 03-15-2010, 06:38 PM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
I like
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #15 of 272 Old 03-15-2010, 06:46 PM
linusb
You are the man to get that Jeep back to running!!!
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
yj with a mail basket yjcrawlr YJ Wrangler Technical Forum 12 07-25-2009 09:21 PM
ever seen a hood basket Rob95YJ YJ Wrangler Technical Forum 6 07-11-2009 10:52 AM
Cargo Basket help mountaineerjp TJ Wrangler Technical Forum 3 07-12-2007 11:36 PM
Basket for slant bar howellru YJ Wrangler Technical Forum 6 12-09-2006 09:12 PM
basket on hard top? chrisvr6 TJ Wrangler Technical Forum 1 07-19-2005 10:15 AM
