-   -   I call it the Basket Case. (http://www.jeepforum.com/forum/f12/i-call-basket-case-989208/)
remmons 03-11-2010 02:30 PM
265 Attachment(s)
I have had several inquiries regarding my YJ project. So I decided to start my own thread regarding the vehicles, parts and progress.
It all started out with the purchase of a 1988 YJ Laredo for three bills, and a 1988 XJ for one bill. The YJ was missing the tranny, transfer case, drive shafts, interior pieces like the front seats, and most of the dash was missing also.
It did have a MPI conversion started, but I am willing to bet that the PO had given up on this daunting task.
At this point, I can virtually do what ever I want to this thing. I elected to keep the motor that was dropped in, and use the Cherokee as a parts donor.
timoteo1234 03-11-2010 02:35 PM
Pictures arent working for me. But sounds like a cool project. keep updating.
remmons 03-11-2010 02:38 PM
265 Attachment(s)
The '88 XJ is a parts vehicle for the Wrangler.
Attachment 108377
It has no title, and it was not in running condition. The parts were strewn through out the interior. It appears that the PO had taken the top end off the motor to see why it did not turn over. I had discovered, during the tear down process, that the flex plate was broken.
Attachment 108378
I had recently purchased a new flex plate in order to begin the resurection.
I also noticed that the fuel tank wires were damaged.
Attachment 108379
I am willing to bet that a PO had misdiagnosed his engine troubles and dumped the Jeep with little knowledge as to what was really wrong. On this Jeep, the Crankshaft Sensor is the ring on the flex plate. So getting no timing AND no fuel was probably very frustrating for him.
Now, onto the project. I will keep this progress posted as time permits.
remmons 03-11-2010 02:39 PM
265 Attachment(s)
Very interesting. I just had them working a few minutes ago. I will work on this.
timoteo1234 03-11-2010 02:41 PM
nice, there they are. thanks.
remmons 03-11-2010 02:43 PM
265 Attachment(s)
No problem.
green89yj 03-11-2010 07:29 PM
sweet. thanks for the link and good luck. I am slowly assembling parts trying to get mine all back together. How complete is the wiring harness and engine on the cherokee? Could you tell me what the bundle coming out of the harness near the firewall side of the valve cover and I think going through the firewall is for? There are two bundles coming out there, the smaller one has a hose in it which I think is for the wiper motor and sprayer but the bigger bundle was completely cut and I don't know where it goes.
remmons 03-12-2010 10:12 AM
265 Attachment(s)
I will have all the wiring figured out by this weekend.
There were three sets that passed through the firewall, plus the firewall connector. One of the sets was for the tail section including tail/stop lights, rear wiper and defrost, dome lights and the fuel pump. It also had the E-brake wire and the seat belt reminder wire set. I should have taken pics of the tear down process, but I was more worried to get that XJ out of my wifes parking spot.
I took virtually every part of the wiring harness, short of a couple feet of dome light wire. I did notice that the engine in the YJ had some upgrades performed before I bought it. It has been upgraded with the 4.0L head, intake and exhaust, and the engine compartment wire harness, so I will have to perform some cross referencing on this as well.
I managed to spend about an hour and a half on the tranny/transfer case install last night. This is where I am at thus far. (The transfer case pic did not turn out right).
Attachment 108540
I got the tranny bolts tightened to spec. I also got the transfer case installed and tightened to spec as well. While I was under there, I checked to see if my drive shaft that I bought from winners97tj would fit. It was a perfect fit. I will be replacing the U-joints before I install it.
I also managed to get the left motor mount installed last night.
Attachment 108541
It was missing when I bought the Jeep. I had to wrangle the motor around with a floor jack, and a chain hoist suspended from the garage rafters in order to get the mount holes to line up.
I was satisfied to this point with the install. So for now, the easy part is over with.
remmons 03-15-2010 04:52 PM
265 Attachment(s)
I managed to get in a full day over the weekend to work on the basket case. This is what I have thus far.
I discovered that the tranny mount would not line up with the YJ skid plate, so I drilled some holes to accept the mount.
Attachment 109204
So far, so good. I did have to take a BFH to the part of the skid plate where the NP242 hung down at for vlearance.
Attachment 109205
Attachment 109206
The easy pert is over. Now onto the linkages.
remmons 03-15-2010 04:58 PM
265 Attachment(s)
I placed the transmission shifter assembly into the stock 5 speed hole and determined that it was in an adequate place. I then determined the best place to drill out a firewall pass through for the cable.
Attachment 109208
This is my initial placement before setting the shifter assy. to the right side of the hole.
Attachment 109209
Here, it is passing through the firewall on the engine side. It is looking good for clearance from moving parts and exhaust at this point.
Attachment 109210
remmons 03-15-2010 05:06 PM
265 Attachment(s)
I reused the original transfer case shifter linkage bracket for the YJ. I had to bend the tabs to conform to the body contours, but it worked out great after it was done.
Attachment 109211
Here the linkage is all together. I did have to bend the mode rod into a zee shape by 2-1/4" in order to compensate for the offset placement of the transfer case shifter.
Attachment 109212
The end result of the shifters mounted. I only had to trim out about an inch of metal around where the transfer case shifter bucket recesses into the tranny hump.
Attachment 109213
The shifters work with no problem. I can get it into every gear with little trouble.
remmons 03-15-2010 05:09 PM
265 Attachment(s)
I am now moving onto the wiring of the basket case. I will have more tomorrow.
Fernando 03-15-2010 06:03 PM
Nice Project! Keep us posted!
Tshark299 03-15-2010 07:38 PM
I like :thumbsup:
linusb 03-15-2010 07:46 PM
You are the man to get that Jeep back to running!!!
The time now is 11:02 PM.
