Jeep Enthusiast Forums banner
I call it the Basket Case.
55K views 271 replies 57 participants last post by  remmons
#1 · (Edited)
I have had several inquiries regarding my YJ project. So I decided to start my own thread regarding the vehicles, parts and progress.
It all started out with the purchase of a 1988 YJ Laredo for three bills, and a 1988 XJ for one bill. The YJ was missing the tranny, transfer case, drive shafts, interior pieces like the front seats, and most of the dash was missing also.
It did have a MPI conversion started, but I am willing to bet that the PO had given up on this daunting task.
At this point, I can virtually do what ever I want to this thing. I elected to keep the motor that was dropped in, and use the Cherokee as a parts donor.
See less See more
5
#3 ·
The '88 XJ is a parts vehicle for the Wrangler.
Automotive parking light Tire Wheel Automotive side marker light Car
It has no title, and it was not in running condition. The parts were strewn through out the interior. It appears that the PO had taken the top end off the motor to see why it did not turn over. I had discovered, during the tear down process, that the flex plate was broken.
Automotive tire Asphalt Road surface Tread Gas
I had recently purchased a new flex plate in order to begin the resurection.
I also noticed that the fuel tank wires were damaged.
Fluid Wire Pest Parasite Fashion accessory
I am willing to bet that a PO had misdiagnosed his engine troubles and dumped the Jeep with little knowledge as to what was really wrong. On this Jeep, the Crankshaft Sensor is the ring on the flex plate. So getting no timing AND no fuel was probably very frustrating for him.
Now, onto the project. I will keep this progress posted as time permits.
#7 ·
sweet. thanks for the link and good luck. I am slowly assembling parts trying to get mine all back together. How complete is the wiring harness and engine on the cherokee? Could you tell me what the bundle coming out of the harness near the firewall side of the valve cover and I think going through the firewall is for? There are two bundles coming out there, the smaller one has a hose in it which I think is for the wiper motor and sprayer but the bigger bundle was completely cut and I don't know where it goes.
#8 ·
I will have all the wiring figured out by this weekend.
There were three sets that passed through the firewall, plus the firewall connector. One of the sets was for the tail section including tail/stop lights, rear wiper and defrost, dome lights and the fuel pump. It also had the E-brake wire and the seat belt reminder wire set. I should have taken pics of the tear down process, but I was more worried to get that XJ out of my wifes parking spot.
I took virtually every part of the wiring harness, short of a couple feet of dome light wire. I did notice that the engine in the YJ had some upgrades performed before I bought it. It has been upgraded with the 4.0L head, intake and exhaust, and the engine compartment wire harness, so I will have to perform some cross referencing on this as well.
I managed to spend about an hour and a half on the tranny/transfer case install last night. This is where I am at thus far. (The transfer case pic did not turn out right).
Motor vehicle Automotive tire Automotive exterior Bumper Gas
I got the tranny bolts tightened to spec. I also got the transfer case installed and tightened to spec as well. While I was under there, I checked to see if my drive shaft that I bought from winners97tj would fit. It was a perfect fit. I will be replacing the U-joints before I install it.
I also managed to get the left motor mount installed last night.
Motor vehicle Vehicle Automotive exterior Gas Rim
It was missing when I bought the Jeep. I had to wrangle the motor around with a floor jack, and a chain hoist suspended from the garage rafters in order to get the mount holes to line up.
I was satisfied to this point with the install. So for now, the easy part is over with.
#9 ·
I managed to get in a full day over the weekend to work on the basket case. This is what I have thus far.
I discovered that the tranny mount would not line up with the YJ skid plate, so I drilled some holes to accept the mount.
Automotive tire Wood Bumper Automotive exterior Gas
So far, so good. I did have to take a BFH to the part of the skid plate where the NP242 hung down at for vlearance.
Motor vehicle Automotive tire Bumper Automotive exterior Gas
Tire Automotive tire Vehicle Motor vehicle Automotive lighting
The easy pert is over. Now onto the linkages.
#10 ·
I placed the transmission shifter assembly into the stock 5 speed hole and determined that it was in an adequate place. I then determined the best place to drill out a firewall pass through for the cable.
Hood Motor vehicle Automotive tire Bumper Automotive lighting
This is my initial placement before setting the shifter assy. to the right side of the hole.
Motor vehicle Automotive tire Hood Bumper Automotive lighting
Here, it is passing through the firewall on the engine side. It is looking good for clearance from moving parts and exhaust at this point.
Motor vehicle Automotive tire Automotive fuel system Automotive design Automotive exterior
#11 ·
I reused the original transfer case shifter linkage bracket for the YJ. I had to bend the tabs to conform to the body contours, but it worked out great after it was done.
Vehicle Crankset Motor vehicle Wood Bicycle chain
Here the linkage is all together. I did have to bend the mode rod into a zee shape by 2-1/4" in order to compensate for the offset placement of the transfer case shifter.
Automotive tire Wheel Motor vehicle Automotive exterior Rim
The end result of the shifters mounted. I only had to trim out about an inch of metal around where the transfer case shifter bucket recesses into the tranny hump.
The shifters work with no problem. I can get it into every gear with little trouble.
#16 ·
I wanted to post this pic of the transfer case rod that needed to be bent, but I did not have a good pic before today.
Automotive tire Bicycle tire Wheel Motor vehicle Wood
I did not get as much time into this as I would have liked to Monday night, but I know more about the motor, wiring and fuel system that has been transplanted into the Wrangler. After careful cross checking the components and wire colors, I discovered that this is from a '91-'95 Cherokee XJ. I am pleased to learn this, but this also creates an additional challenge to graft an '88 XJ harness into a '91+ XJ and an '88 YJ harness. I have seen in a couple build threads on how the authors approached the wiring dilemna. I am hoping that the '88 engine harness will be a direct plug-and-play into the components, but I will find out for sure when I start checking terminal plugs and routing.
This is from under the dash of the YJ.
Wood Electrical wiring Gas Engineering Machine
I am starting with a clean slate on the YJ dash. I should be able to graft in the XJ harness along with the YJ harness.
Motor vehicle Automotive exterior Gas Electrical wiring Machine
Since the YJ was carbureted, I decided to strip it all out and start fresh. Hopefully, I have made a good decision. I will find out soon enough.
#17 ·
I managed to spend some time on this on Tuesday, but not Wednesday. All I manged to do was sort out the spaghetti mess called a wiring harness.
In the box of goodies, I found two ECMs. The first one is the original '88 YJ ECM.
Gas Bumper Machine Motor vehicle Automotive exterior
The second one I found was that of the 93+ Cherokee XJ.
Motor vehicle Electrical wiring Gas Auto part Automotive exterior
It was dated 8/10/92 as seen in this pic.
Material property Font Bicycle part Auto part Rim
This one was the one from the '88 XJ that I had stripped out.
Electrical wiring Gas Electrical supply Cable Electronic device
With the knowledge that I have of the '93 plus wiring and ECM, my '88 wiring and ECM has been packed away into a box until future use or sale.
Tire Automotive tire Wheel Motor vehicle Vehicle
Hopefully, with the help of some of the threads on here for aimed at the 4.2 to 4.0 conversion, I will have this all figured out by the end of the weekend! (Crossing fingers).
#18 ·
glad to see you are making progress. I'm a little stalled out at the bulkhead connector because I still have the 89 yj under dash wiring.
#19 ·
I am at that point also. I did go out to the garage last night and I picked through the spaghetti mess seeing what wire went where. I will be cross referencing them with the manual(s) tonight when I get home from work.
In the mean time, I did have some success with the stering column.
I had one heck of a time trying to figure out why my dommer switch did not work. After tearing down the column on my '65 (steering upgrade) I found out why.
Wood Rectangle Composite material Font Auto part
This was missing in my box of parts.
The column is in and functional!
Steering part Motor vehicle Steering wheel Vehicle door Automotive exterior
I have a heater control assy. with broken mounting tabs. Plus I need the control cables, the plastic retainers were ripped out mercilessly. So, I will be in the market in the near future for these parts.
Camera lens Reflex camera Point-and-shoot camera Digital camera Cameras & optics
The wiring conversion has started. It will take me some time to get this finished.
#21 ·
I had to laugh a little at your time comment. Time? I really don't have any free time. I take all my free time away from my family in order to work on this Jeep. They know that it will be well worth it in the long run, they are excited to go Jeepin, convoy style. With my '88 wrangler, my wife's '07 Unlimited and our daughters '65 CJ5A, it will be a fun summer!:2thumbsup:
#23 ·
Yeah, it does have an excellent foundation to build upon. The tub is in as good a shape as anyone can expect. Thanks to the P.O. I have more work, but I have less work. I could have dropped in a 350/TH400/D20, but the D20 was the wrong side front output. So, I created a headache by continuing what was started. I am sure that it will be well worth it when it is all finished.
#24 ·
I was reading this and just thought "wow, this is an intense project." Then I read you are in Vernal. If you need help with anything major, I end up out that way at least a few times a month, I'm sure I could swing by and help a fellow Utah jeeper :cheers2:
#25 ·
Thanks! I will keep you in mind.
Yes, this is an intense project, but it was one that I was willing to tackle. My wife is almost sick of me dragging old Jeeps home, it took me a little convincing to allow this one to follow me home.:rofl:
I have not been able to do much on it this week due to my wife trainging as a Census taker, but I did manage to look and record the wiring. I did record every wire in the blocks, but decided to look at what I really needed and record those wire color codes.
Handwriting Font Rectangle Paper Paper product
Handwriting Font Rectangle Wood Parallel
I do not have the exact locations correct as to wire terminal placement in relation to the blocks, but for my references, they work fine.
Hood Motor vehicle Automotive fuel system Automotive exterior Electrical wiring
Motor vehicle Electrical wiring Computer hardware Cable Gas
I have narrowed down the wires from 46 to 18, quite the drop in required wiring. I should have the wiring 75% complete by the time Monday rolls around.
#26 ·
I have been MIA for a few days, heck I haven't been able to spend the quality time needed with my YJ.
Last night, I managed to locate what dash pieces that I had and assembled them.
Gauge Measuring instrument Automotive exterior Automotive lighting Gas
The finished pic! I was glad to make some progress!
Vehicle Motor vehicle Car Odometer Automotive lighting
So far, the foglight switch is all that I am missing for the drivers side part of the dash to be complete!
Motor vehicle Gas Electrical wiring Auto part Cable
#27 · (Edited)
And now, some more wiring decoding.
Throughout the past week, I have been able to record wire colors and cross reference them to where they go.
I came across this "layout" sheet that I made for when I converted the 1965 CJ5A to power steering. It may come in handy for the Basket Case. I purchased a Painless Ignition Switch Conversion kit, I found this to be quite useful when I reworked the wiring under my CJ dash.:D
Font Parallel Number Document
#28 · (Edited)
The 88 YJ under dash wire colors and their locations. I did not have a basis for how to identify the harness block,:confused: so I made one that I could follow.:D
1988 YJ wire colors and their locations. (I believe that the 87-90 carbureted are the same or similar)
Font Number Parallel Document Paper
1993 Cherokee XJ (1991-1995) wire colors and their locations.
I have changed my mind somewhat since this time to concentrate on what was needed to convert the 88 YJ dash to the 93 XJ engine side. I will have some of that coming up hopefully in the next installment.
#29 ·
The one that has Bendix on it is abs brake control module. Since you installed the auto did you also grab the tcu ?
#32 ·
That just may come in handy! I think I will take you up on that, if you don't mind.
Last night, I went through some more of the wiring. I now have a conversion chart started. Sometimes, after some time of looking at the spaghetti mess, my eyes start to hurt and my mind starts to go loopy.:D
#34 ·
Thanks! I feel, honored! (Butterflies in stomach). There are other build threads on here that are more advanced than mine is, I merely started on someone elses project and took it over. Of course I have twice the work to do, I am still figuring out what the P.O. had done in order to procede from there.:D
Once I get this Jeep to running state, I will be able to do what I want as far as lifts and accessories. Who knows what I can do with a chop saw, a welder and some tubing.:laugh:
Top
