I bought a 4.0l engine for $10! - Page 2 - JeepForum.com
post #16 of 25 Old 04-12-2010, 05:49 PM Thread Starter
89blackwidow
Originally Posted by Reverb View Post
Wire brush that rust off and see if thats a crack on the left. I think thats a mounting point though so you should be in the clear.
Yeah the pic doesn't do it any justice but the area to left is actually a little tab or fin that comes out away from the block. I took a scribe to it and flaked off the loose stuff, but it looks only to be surface, so I think I am good.
89blackwidow is offline
post #17 of 25 Old 04-12-2010, 05:52 PM Thread Starter
89blackwidow
Originally Posted by timatoe View Post
Where you at in NorCal? There's lots of us in the Sac area that would probably be willing to help out.
I appreciate the offer but I live about 6 hours north in Humboldt county.
post #18 of 25 Old 04-12-2010, 07:26 PM
timatoe
timatoe's Avatar
Yeah, that's a little too far. Good luck though.
timatoe is offline
post #19 of 25 Old 04-12-2010, 07:41 PM
Wheelman286
Originally Posted by iluvtruenos View Post
It is a 95+.
The oil cap is a clicky type that screws on. The Earlier ones had two tabs.
My 92 has a screw oil cap just like his. It came with it too.
92 Wrangler 4.0 5-speed -Canyon Blue Metallic/Black Interior '00 S2000 Silverstone Metallic/Red Interior '93 S-10 Blazer Tahoe LT Black/Grey Leather Interior
Wheelman286 is offline
post #20 of 25 Old 04-12-2010, 08:27 PM
imstillatwork
I grew up in sohum
imstillatwork is offline
post #21 of 25 Old 04-13-2010, 07:06 AM
Alfons
No harness or computer. I think I will probably take my time on this and break it down to replace the bearings, rings etc. I also take the block to get new freeze plugs put in.
Before you start into all this rebuild and parts acquisition (most of the drive train, computer, wiring harness, etc.), it might be worthwhile making a comprehensive list of what you need and then seeing what the whole project is going to cost you. Personally, I wouldn't rebuild a 4.0, especially if I also had to get the transmission, transfer case, drive shafts, etc. I would find a doner vehicle that has a small V or some variety (V6 or V8 - I prefer GM for this) and take as much of the drive train and electronics as I would need for the swap. You'll end up with more available power and better economy with this type of swap.
Alfons is offline
post #22 of 25 Old 04-13-2010, 07:49 AM
Fhajad
Why not rebuild a 4.0?
I can get a rebuilt kit for like, $450 that has everything in it but the crankshaft and machining.
Fhajad is offline
post #23 of 25 Old 04-13-2010, 08:35 AM Thread Starter
89blackwidow
I agree with you about making a list of parts I will need for the swap. I also need to take the time and do some more research. I plan on getting another vehicle this time next year which will allow me to tackle this project without feeling rushed. I plan on using my transfer case from my 2.5l and finding an AX15 tranny. I also had already planned on putting a SYE on it also. I thought about doing the V8 swap but feel I'll need to replace alot more parts such as radiator, axles etc. than doing the 4.0 swap.
post #24 of 25 Old 04-13-2010, 09:55 AM
matko25
i would suggest lifting the tub off it will make everything easier
matko25 is offline
post #25 of 25 Old 04-13-2010, 10:09 AM
Allen52105
I live in eureka if you need any help with the jeep
jason
Allen52105 is offline
Just Bought a 98 that was Overheated: Replace Engine? Woodyhfd TJ Wrangler Technical Forum 7 02-24-2010 09:35 PM
4.0 engine knocking after I bought it elewis12345 TJ Wrangler Technical Forum 5 10-14-2009 03:47 PM
Just bought a YJ, might have swapped engine? roblun YJ Wrangler Technical Forum 16 08-29-2009 08:40 PM
Just bought a JK LilViper95 Wrangler General Discussion 1 11-24-2008 08:52 PM
I Just bought this! EaglesSJ TJ Wrangler Technical Forum 22 09-20-2006 09:33 AM
