I-4, 32's and not re-gearing? - JeepForum.com
post #1 of 4 Old 03-28-2002, 02:16 PM Thread Starter
andy95yj
Anyone have an I-4 and running 32’s without re-gearing? How does it work, what is the RPM at 60 mph, would you recommend it?
Thanks
andy95yj is offline
post #2 of 4 Old 03-28-2002, 02:38 PM
Bigrubberjeep
Go for it, RPM is think is about 30K or so. The 4:10 gears can hadnle up 33" actually however lot's of people recomend regearing.
To Jeep or not to Jeep, what's the question?
Bigrubberjeep is offline
post #3 of 4 Old 03-28-2002, 05:11 PM
bluYJ
You have the 4 cyl, but do you have auto or 5 spd?
My current YJ has 4 cyl and auto trans with 32's.
This jeep came with 3:73 gears and was ok around town,but couldn't get to 70 mph on the highway with the 32's. Now has 4:88 gears (revs a little higher on the highway -around 3500, but will now actually pull up those same stretches of highway at 70-75 mph). A previous YJ of mine had 4cyl and 5 spd (again with 32's)(stock with 4:10's).
Again, that jeep did ok around town, but 5th gear was useless on the highway (and couldn't hold speed going up hills). I put 4:56 gears on that jeep which helped for the most part. It could use 5th gear on the highway except on steep or long highway inclines (always wanted 4:88's for that jeep, but they weren't available at that time).
95 yj, 4 cyl, auto trans, 4 1/2" Rubicon Express extreme duty lift,
33" BFG Muds, 4:88 gears, Detroit's front and rear, Dana 44 rear axle with disc brakes, heavy duty Dodge NP231,SYE, MORE sport cage. Blue Jeep Club Member #61
bluYJ is offline
post #4 of 4 Old 03-28-2002, 06:26 PM Thread Starter
andy95yj
Sorry, I have a 5 speed
andy95yj is offline
32's with 3.73 gearing?????? TTLex TJ Wrangler Technical Forum 7 04-28-2009 04:56 PM
anybody have 2.5L 32's and stock gearing? MC_NickP TJ Wrangler Technical Forum 15 01-30-2009 05:10 PM
Gearing to run 32's on a DD U.S.MarineLJ TJ Wrangler Technical Forum 23 11-08-2005 04:23 PM
Gearing for 32's & Towing Tispco TJ Wrangler Technical Forum 4 05-15-2005 06:52 AM
Re-gearing on 32's??? MBrit13 YJ Wrangler Technical Forum 14 11-07-2004 04:36 PM
