I-4 2.5L 89 YJ refuses to start - runs rich if at all - JeepForum.com
post #1 of 22 Old 09-17-2013, 04:01 PM Thread Starter
JeepArt
Ok Jeepers, I'm looking for some advice.
Bought a 89 YJ I-4 2.5L and I've hit a snag. The jeep (when running) runs very rich. Black exhaust marks on the pavement where it's been idling, carbon fouling on the spark plugs and so on. Now to compound the issue, it refuses to start at all. Trying to start results in a gas odor from under the hood and no ignition.
Here's what I've done and tested:
  • Replaced distributor cap and rotor
  • Tested for spark (successful)
  • Replaced plugs
  • Replaced MAP sensor
  • Replaced O2 sensor
  • Replaced CPS
  • Cleaned Throttle Body Injector
  • Tested for fuel flow (successful)
  • Replaced fuel filter
  • Replaced air filter
Questions:
  • Any suggestions on other things to check to get her started?
  • What could cause her to run so rich when running?
  • I'm speculating the TBI could be a factor...what are the odds?
  • I haven't replaced the TPS yet but have one on order...should I do that as well?
Thanks in advance for your help getting this girl up and running.
JeepArt is offline
post #2 of 22 Old 09-17-2013, 04:23 PM
Siva283
[*]Replaced distributor cap and rotor[*]Tested for spark (successful)[*]Replaced plugs[*]Replaced MAP sensor[*]Replaced O2 sensor[*]Replaced CPS[*]Cleaned Throttle Body Injector[*]Tested for fuel flow (successful)[*]Replaced fuel filter[*]Replaced air filter
Questions:
[*]Any suggestions on other things to check to get her started?[*]What could cause her to run so rich when running?[*]I'm speculating the TBI could be a factor...what are the odds?[*]I haven't replaced the TPS yet but have one on order...should I do that as well?
Do a fuel pressure test. I am betting you have a bad pressure regulator. You should have I think its 14 psi with the tbi. Someone will need to verify that though.
Sent from my SPH-L300 using JeepForum
Ask me how I know...
Siva283 is offline
post #3 of 22 Old 09-17-2013, 04:31 PM Thread Starter
JeepArt
Would low fuel pressure be symptomatic of running rich when running at all?
JeepArt is offline
post #4 of 22 Old 09-17-2013, 05:25 PM
Siva283
No but high fuel pressure would.
Siva283 is offline
post #5 of 22 Old 09-18-2013, 07:09 AM
Que89YJ
The pressure is only 14 psi on the TBI. You should look at the rebuild kit with replacement injector for the throttlebody. This is in the Schaef thread below:
How to google the forum:
http://www.jeepforum.com/forum/f12/f...oogle-1003734/
To download the fsm:
http://dl.dropbox.com/u/40590346/87-88%20YJ%20Jeep%20Wrangler%20FSM%20manual.pdf
http://dl.dropbox.com/u/40590346/1990%20Jeep%20Factory%20Service%20Manual.pdf
If you download the FSM and you are not a member of dropbox, please PM Ninjakid and join under him. It gives him more space to store and it is a real generous thing to get the manual for free!
http://jeepspace.jeepforum.com/ninjakid
Also lots of good info in Shaef's threads about his TBI:
http://www.jeepforum.com/forum/f12/8...ocess-1293442/
http://www.jeepforum.com/forum/f12/2...-idle-1293410/
Get a multimeter. Some of the pre 91 tbi sensors require an adjustment to setup when replaced. Since you are dealing with PO that probably didn't know, chances are you need to do some adjustments with the basic tune up. Wide open throttle switch(WOT), the throttle position sensor(TPS), Idle Speed Adjustment Motor(ISA), and the fuel pressure on the throttle body.
Que89YJ is offline
post #6 of 22 Old 09-18-2013, 07:11 AM
Que89YJ
Sorry, ignore the injector thing for now. Read through the thread and it tells you about measuring the pressure. x1000 with Siva. Measure it!
Que89YJ is offline
post #7 of 22 Old 09-18-2013, 07:57 PM Thread Starter
JeepArt
Will do on the pressure check...if I can get the Jeep running. The problem I'm facing now is that the engine won't start. Fuel is being delivered, plenty of spark, but no ignition. Ideas? It's headed for the shop if I can't get this figured out. TIA
JeepArt is offline
post #8 of 22 Old 09-18-2013, 08:08 PM
Que89YJ
No ignition.... Yes. Check power at the coil. Replace the coil ICM. Most good parts stores have a testor for it. You can check fuel pressure by jumping the fuel pump relay with a small wire between 30/87 in the relay socket.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #9 of 22 Old 09-18-2013, 08:16 PM Thread Starter
JeepArt
What's odd is it was running, rough and rich mind you, but it was running. Maybe this helps... When it was running it ran Ok until I stopped the Jeep then it wouldn't restart, even with starter fluid.
JeepArt is offline
post #10 of 22 Old 09-18-2013, 08:18 PM
Xpress
Check the fuel pressure before you do anything else.
All about that unibody life.
Xpress is offline
post #11 of 22 Old 09-18-2013, 08:24 PM Thread Starter
JeepArt
I'm picking up a fuel pressure gauge tomorrow along with a new TPS which I was planning to install anyway. Another observation: after cleaning the TBI I fired the engine and saw what looked like a good amount of fuel come from the injector into the throttle body.
JeepArt is offline
post #12 of 22 Old 09-18-2013, 08:28 PM
95YJRusso
Does the starter motor turn over?
Had I known Jeeps were going to be this addicting, I probably never would have bought one!
95YJRusso is offline
post #13 of 22 Old 09-18-2013, 08:33 PM Thread Starter
JeepArt
Starter motor turns over. I get spark from the distributor. New plugs all checked and gap. Visually confirmed fuel into the throttle body and out of the injector.
I can't help but think it's electrical/computer related because of the hatchet job the previous owner did on the wiring to install a stereo (turn on the headlights and the radio loses power... Go figure.)
JeepArt is offline
post #14 of 22 Old 09-18-2013, 09:20 PM
Que89YJ
Check the pressure. If you are getting spark then there is only fuel and timing. I miss understood what you said about spark. Siva is right.
Fault codes:
No Start:
Que89YJ is offline
post #15 of 22 Old 09-19-2013, 07:09 AM
Siva283
I remembered some of what you taught me.
Siva283 is offline
