Hydrolocked....new engine time - JeepForum.com
post #1 of 6 Old 09-22-2004, 08:43 PM Thread Starter
raZe
Well, after ripping apart my friends 1990 2.5L engine, I disocvered bent rods and valves, We are going to swap in a junkyard 2.5L into it, this should be an easy swap correct? it's the same motor and all so I just should be able to disconnect the dead engine and swap in the other one, hook it up and go ?
raZe is offline
post #2 of 6 Old 09-23-2004, 06:41 AM
JayJEEPguy
JayJEEPguy's Avatar
I don't see why not.
Just make sure to get a motor with the same fuel injection system, as there were 2 different ones, I believe.
Jason T.
'99 GMC Suburban: Gas-guzzling people mover with 18" Z71 wheels
'04 WJ:Special Edition. V8, QTII, 2"BB, Bilsteins & 245/75/16" Goodyears
'02 WJ:4.7L, Selec-Trac. Totalled 9-12-07. Click to hear
JayJEEPguy is offline
post #3 of 6 Old 09-23-2004, 07:45 AM
Bugga360
I think the 90 2.5 might be throttle body injection, but my 92 is a multi port injection.
1992 Black YJ 2.5... !!!LT1 in the works!!!
4" Skyjacker Softride Kit, Aussie Locker, No Swaybar, No Trackbars, 33 x 12.50 Mud King XT, 15x10 Cragar Soft 8, Bullet Pro Turbo Muffler and Magnaflow Mirror Finish High-Flow Cat, Optima Yellow-Top
Bugga360 is offline
post #4 of 6 Old 09-23-2004, 08:22 AM
Why J?
Why J?'s Avatar
if yuou get an engine that in not an 89-90 you will have to switch over the intake manifold and valve cover and maybe the distributor. but the block and everything else should be the same.
wait i take that back you will also have to switch the sensors because after 91 they switch to a obdII system.
Why J? is offline
post #5 of 6 Old 09-23-2004, 06:07 PM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
I thought OBD-II didn't come 'til much later? Like mid-90s if YJs were equipped at all... I mean my YJ is carb'd so I'll admit I'm no expert on ECUs, but I thought that's what I heard.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #6 of 6 Old 09-23-2004, 10:25 PM
Coot
OBD II is 96 and newer. make sure the 2.5L you get is 87-90 b/c they are TBI. 91-95 are MPI OBD I
92 Jeep YJ, 4 Banger, Cold air intake, Electric fan, 1 inch motor mount lift, 8.8 rear axle Limited Slip 4.10's, SOA, 2 inch body, 35x12.5 Pro Comp MT on 15x8 AR-767
Coot is offline
Who has Hydrolocked their JK luigi0523 JK Wrangler Technical Forum 1 10-29-2009 12:06 PM
Hydrolocked at 2800 miles Creashion JK Wrangler Technical Forum 35 11-10-2008 08:36 PM
hydrolocked engine... Baller_63 TJ Wrangler Technical Forum 16 04-12-2008 03:40 PM
Time for the engine swap!! Zorm YJ Wrangler Technical Forum 2 06-08-2007 11:38 AM
i'm sure we get this all the time but engine replacement newtrail YJ Wrangler Technical Forum 0 01-30-2007 04:27 PM
