Hydro steering - JeepForum.com
post #1 of 10 Old 12-09-2008, 06:51 PM Thread Starter
Bridgeman
Hydro steering
Alright what is everyone's opinion on hydraulic ram steering for an 88yj
Bridgeman is offline
post #2 of 10 Old 12-09-2008, 07:04 PM
yjcrawlr
Full hydro is for trail rigs only. Hydro assist is not needed for 35s or smaller. You can run hydro assist on the street, your steering box will need to be drilled and tapped, and mounts will have to be fabricated and welded. I will eventually need to step up to this but my jeep actually steers well with 37s and highsteer on a chevy dana 60. 42s might be a different story.
90 YJ 102 in wb stretch, SOA, dana 60, 14 bolt welded,4.56s, 37in Parnelli jones dirt grips, currie twin stick dana 300, york oba, tractor link traction bar, full custom armor,poison spyder tube fenders, 95Cherokee High Output 4.0
2014 JKU, modified Rubicon Rails, RC stubby with warn 8000m, 2" leveling springs and OME trim spacers, Superchips Flashcal, Spidertrax wheel spacers, rubi shocks, and Lots more mods soon!!!
yjcrawlr is offline
post #3 of 10 Old 12-09-2008, 08:05 PM
jason m
Nothing but the facts
jason m's Avatar
we need more info from ya than what your giving. unless you all ready have a decent built axle its not worth installing it onto a dana 30 with 33's. agin as yjcrawler said hydro assist is not even needed till you hit 35-37's. i still have power steering and i can turn 39's, i run a large cooler tho and that help alot.
jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #4 of 10 Old 12-09-2008, 08:38 PM Thread Starter
Bridgeman
currently I'm running 35's but once I swap to the hpdana44 I hope to run 37's. Thanks for the info
post #5 of 10 Old 12-10-2008, 07:40 AM
1 ton yj
1 ton yj's Avatar
Do you want a hydraulic asisst or a fully hydraulic system?
1 ton yj is offline
post #6 of 10 Old 12-10-2008, 02:56 PM Thread Starter
Bridgeman
If I went to this system I would probably go full hydro
post #7 of 10 Old 12-10-2008, 03:57 PM
iwishihad1
1) full hydro isnt legal on the road
2) unless your running a HUGE..i mean 40 plus inch tire, full hydro isn't needed
3)hydro assist is fairly easy to do
4) stock inverted t steering wont work with hydro assist, and wont nearly be strong enough....build cross over steering with some DOM and youll be good to do
[CENTER]1995 fire red XJ, new 4.0, ARB safari snorkel, sye, front DS, aussie locked 8.8 5:13s 38 SXs, trussed/locked 44 front, hydro assist, DOM steering/COLOR]
YJ. 91 body, body off resto, crate chevy 350, 700r tranny, 2 inch springs, SOA, ford 9 rear, dana 44 front, both detroits, cage, 4:88s, and 36X14.50s. strictly street queen
iwishihad1 is offline
post #8 of 10 Old 12-10-2008, 04:45 PM
1 ton yj
1 ton yj's Avatar
1) show me where that is written.
2) I beg to differ, look at every WEROCK pro-mod rig. They all run 37s and up until 07 had to run a steering box. When the rules changed in 07, almost if not all went to full hydro. I doubt it was to be cool or because they had money burning holes in their pockets
1 ton yj is offline
post #9 of 10 Old 12-10-2008, 05:32 PM
E_ROCK
Hydro assist will work fine for 37" tires. I am not disagreeing with what everyone else is saying about full hydro. Just putting my 2 cent in for hydro assist.
I bought a used Rocklogics Ram. It is on a waggy LP44 with a truss.
http://www.rockfrogs.org/phpBB2/viewtopic.php?t=724
My buddy went with the Redneck Ram setup. HP44 on an XJ
http://www.rockfrogs.org/phpBB2/viewtopic.php?t=2041
another XJ with HP44 and PSC setup
http://www.rockfrogs.org/phpBB2/viewtopic.php?t=1171
Garage Monkey, Wheeling Junkie
E_ROCK is offline
post #10 of 10 Old 12-10-2008, 06:14 PM
iwishihad1
not sure where its written....but you have to still have a "mechanical" link in your steering (ie drag link) full hydro eliminates this. loose hydraulic pressure, and you loose all steering. even if it was legal, it wouldn't be a safe set up for the road
not arguing at all against hydro assist, as i plan on running it eventually..just full hydro isn't necessary. and your comparing apples to oranges with a WEROCK pro-mod rig, and your, im guessing here, mostly stock yj, drivetrain wise atleast
Currie Steering & Hydro Assist - Where to mount ram? tommaho TJ Wrangler Technical Forum 55 06-02-2015 12:10 PM
Cheap Hydro Steering, to good to be true?? Nickb1907 TJ Wrangler Technical Forum 2 09-03-2009 10:01 PM
Full Hydro Steering STEVES89XJE YJ Wrangler Technical Forum 7 03-27-2008 08:30 PM
--> HYDRO ASSIST: HP44, SOA, PartsMike steering Arms, Astro Box. Need help. Big-n-Broke-YJ YJ Wrangler Technical Forum 30 08-26-2007 07:19 PM
Hydro assist steering? Flatbroke TJ Wrangler Technical Forum 3 01-17-2006 11:24 AM
