hydraulic throwout bearing - JeepForum.com
post #1 of 4 Old 12-17-2001, 01:52 PM Thread Starter
evilpsych
evilpsych's Avatar
hey guys.. went to go bleed my clutch line cuz i thought it had air in it from one of my earlier posts.. the metal lines going into the trans were awfully loose.. i attached the bleed line, and pumped the clutch twice and fluid was everywhere.. i figure the tubing snapped off or came loose. anyway.. how much should it cost me to get this done? autozone has the bearing for $99.. i got a quote from the local dealer here for $670 installed..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 4 Old 12-17-2001, 06:20 PM
byj92
$670??? no way...find someone else...my line snapped a few months ago, which sucked...i took it to a local mechanic and it was $250 installed...maybe i just found a good deal, but 670 is way excessive
byj92 is offline
post #3 of 4 Old 12-17-2001, 09:02 PM
igofshn
Locked @ both ends
igofshn's Avatar
If you are replacing the throw out bearing, you should also change the clutch. Shouldn't be any more in labor because they are removing it anyway too get to the throw out bearing. If the bearing is bad then you know the clutch will be going soon. It isn't a very hard job. Just drop the tranny, Everything is right there. Shop manual explains everything. You and a buddy can probably do a complete repair on one saturday
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #4 of 4 Old 12-17-2001, 10:01 PM
bob91yj
Removing the clutch is NOT required to replace the internal slave cylinder/throw out bearing. My buddy and I did mine in about 3 hours start to finish in my driveway. We're both mechanics, and have a tranny jack. It's easily doable on a Saturday with a couple of buds.
Replacing the clutch while you're in there is a good idea though.
Bob
91YJ Sahara, SOA, 4.88's, 35's, Locked
bob91yj is offline
Pilot bearing/Throwout bearing? TJ4JT TJ Wrangler Technical Forum 9 11-03-2009 02:07 PM
spun bearing or throwout bearing bad gearhead1985 YJ Wrangler Technical Forum 5 05-31-2009 12:42 AM
Hydraulic throwout bearing to mechanical.. youngjeeper11 TJ Wrangler Technical Forum 5 01-31-2007 06:31 PM
Quick throwout bearing/clutch/hydraulic Q PhilipJ YJ Wrangler Technical Forum 2 09-02-2006 04:47 PM
hydraulic throwout bearing BrandonParvin YJ Wrangler Technical Forum 1 02-27-2002 03:59 AM
